Thread: D2 Manual links
    Jul 2010
    D2 Manual links
    Hi all
    Started to put my son in laws D2 V8 back together after having heads machined & new gasket set. Was leaking coolant from ends of both heads. I've ordered a rave cd from Dave but it won't arrive for a few days. I tried the manual rave link in Links here but doesn't seem to work anymore. Anyone know a good link that works . Would like to get into it today & get most done if possible.
    Mile
    May 2015
    Williamstown, Victoria
    Have a look at https://www.landyzone.co.uk/land-rov...manual.260227/
    I couldn't get rave to work on 64bit windows 7. I installed VMware, non commercial licence and then installed a 32 bit WinXP in the VMware environment.
    CHeers
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    May 2003
    On The Road
    The link works,, sorta.
    its to a NAS online manual,,
    only loads one page at a time and references to SAI but the basics should be the same,,
    Land Rover Workshop Manuals > Discovery II > ENGINE - V8 > OVERHAUL > Cylinder head - overhaul
    Jul 2010
    Getting there
    Heads on new water pump inlet manifold & alternator bracket
    Enough for Sunday. Will finish tomorrow the rave download eventually worked but very slow.
    Jul 2014
    west of Transylvania
