Results 1 to 6 of 6
Thread: Eternity turbo lag
    Byford, WA
    Eternity turbo lag
    Hi There,
    2002 D2 TD5 manual. I have noticed that on pick-up from a gear change or off from the lights the vehicle is a bit slow on the uptake, then about 1800 rpm it's like someone threw a match on the fire, away we go.
    Not having driven a TD5 manual beore only a 300TDI what I am seeing doesn't feel normal, the lag would be about 2 to 3 seconds under normal acceleration, not foot to the boards stuff.
    I also have what appears to be a high rev missfire, subtle but it is there. I have checked the engine ECU there is no oil at the injector harness at the ECU.
    So far I have checked nothing else.
    Any ideas?
    Cheers Marty.
    Dec 2009
    Baldivis WA
    Mines a manual had had a similar experience when my MAF was failing. But they do seem a bit gutless below 1800rpm anyway.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Aug 2015
    Moe
    Quote Originally Posted by Nomad9 View Post
    Hi There,
    Any ideas?
    I don't have the foggiest notion about what could be causing the hi rev misfire.
    My Td5 manual is as slow as a wet weekend below about 1800rpm. I compensate by keeping it between about 2000 and 3000 rpm where it goes pretty well. A Td5 is not the car to used to zip in and out of traffic methinks...:-)
    Mark F...
    Vk3KW
    2002 D2 Td5 auto - current AKA The Citrus Money Pit
    2000 Disco 2 Td5 Manual - dead and gone
    197? Range Rover - gone
    1973 SWB SIII Diesel, 1968 SWB IIA Petrol, 195? SI Petrol - all gone
    Outback Campers Sturt
    http://jandmf.com
    Jul 2014
    west of Transylvania
    The EGR is still there?, if it is this can cause that so make sure it's not clogged with muck, clean the MAP sensor(in the inlet manifold) anyway unplug the MAF and drive test it so also make sure that the wastegate is not stuck by grabbing the rod and moving it both sides, you must be able to push it toward the turbo about 15-20mm with some force then it should come back freely pulled by it's spring
    Byford, WA
    Hi There,
    EGR has gone, I'll check the MAF..... good idea. I've also de-catted the exhaust, thought that might have been a contributor. I'll check the waste gate opersation that was going to be my next port of call. If this is what it is thats fine, just checking that mine wasn't abnormally slow. My auto TD5 surprisingly seems "zippier", ah well, I'll check the MAF and go from there.
    Thanks for the comments.
    Cheers Marty
    Jan 2011
    X2 for MAF Happened last week in blue mountains for me. Disconnect the plug and see what happens.
