Results 1 to 10 of 17
Thread: 12 pin plug installed but have a question
    Aug 2013
    ACT
    Hi
    Previously I had the standard 7 pin plug with a tekonsha p3 brake controller
    I also have one of those led modules from linear electronics installed
    The other day I had a 7 pin plug installed.
    After the install the brake controller did not work
    The guy had a look and reckoned the brown lead was not connected properly
    He cut the wire and did something and all seemed to work ok
    We tested on a van and still ok
    When I had a look today I noticed the brown wire is not connected to anything see pic, is this right. I know nothing about this stuff if you haven't gathered
    Richard
    Mar 2007
    Kalgoorlie WA
    Sorry - can't help you on what the brown wire is for or whether it should be connected.
    But looking at the installation of the red bullet connector on the blue wire - if anyone did a wiring installation like that on my car, I'd shoot the *****.
    Seriously - it's really not that hard to do the job properly.
    Cheers .........
    BMKAL
    LRD414's Avatar
    Oct 2014
    Richard,
    Hard to say for 100% certainty from your photo but the brown wire does look like the wire in the trailer loom that is supposed to be cut and terminated as part of the standard brake controller install.
    This wiring diagram shows it but the image resolution is poor.
    From this thread:
    http://www.aulro.com/afvb/l319-disco...brakes-56.html
    The brown wire should be insulated once cut so as not to short on anything.
    My guess is the blue wire is your brake signal feed for the trailer, in which case it would be connected to the brown wire heading towards the plug.
    So the poorly terminated brown wire would be heading back towards the front of the vehicle.
    Hope that makes sense.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Aug 2013
    ACT
    I am lost
    It seems from the diagram that the brown wire does terminate and the blue should connect to the other side of the brown
    If that done I would have a spare blue
    I know bugger all about this stuff
    What I forgot to add is that a new 12 pin plug was added i.e. The 7 pin rounds are still there, I am unsure but may be he has run a new wire up there
    What he has done is connected to my fog lights (blue) instead of the the tail light (brown). Is this a problem
    If it sounds like I have an idea now ya wrong as I also contacted Sniegy as have paniced a bit as I am about to pick up a new van
    Agree it looks rough. I had not checked as have been sick.
    Richard
    Richard
    Aug 2013
    ACT
    I am confused further
    In my pic there is a loose brown wire and two blue wires connected
    I have been chasing the threads and it sounds like the blue should be connected to the brown.
    If you did that there would be a loose blue wire
    As mentioned above the guy installed completely new 12 pin plug and left the original 7 pin plugs there
    So what has he done. I think he may have cut the brown from a blue and perhaps run another blue wire from the new 12 pin plug? ?
    I don't know.
    Richard
    Aug 2013
    ACT
    May be showing my ignorance on again but is this right
    I think my blue wire has been connected to the fog lights from what the diagram shows and Sniegy info.
    So does this mean it all will not work
    It comes down to why the blue wire from the break controller is normally connected to the tail light. Is it Theseus the break controller determines the breaks are being applied and to what intensity or is it just a power source.
    If just a power source then does it matter where it is connected to and what I have is ok if not very well done.
    Sorry all the posts but am concerned
    I guess I will find out when I take the van out.
    Richard
    Aug 2013
    ACT
    Sorry about all these posts. I am trying to sort it out a bit before confronting them.
    OK still thinking about this bloody thing.
    It does appear that it has been wired to the fog lights but that is based on the wire colours of the round D4 12N plug.
    As it seemed to work I suspect what I said earlier is true. The guy has run a blue wire to PIN5 on the new plug. The old 12N is brown.
    I also suspect he has disabled my old plug PIN5
    BUT still can not work out the wires.
    BEFORE he did anything the brake controller would have been set up for the 7 pin 12N plug.
    This would be as shown in the diagram
    Blue from the brake controller connected to brown wire and then to pin 5 on the 12N.
    Another blue wire connected to the pin 2 - Fog lights
    AFTER
    He has cut the connected blue and brown wires and left the brown one free
    He has joined that blue wires, I do note they are different shades of blue so who knows which is which
    I think
    The light blue is the old fog light wire
    The dark blue is the wire to the brake controller
    He has connected these together as Sniegy said
    This means he must have cut those wires AND on close examination of my pic in the bottom left hand corner there looks like there is a cut blue wire which has not been terminated. Not sure of the colour but will check it out in the morning. My son is a sparky, not auto, but he looked at it and said why not solder as that is a **** job.
    I am now scared of what else he has done installing the new plug. He was also supposed to do some more work for me which I think I may pass on.
    BLOODY HELL!!!
    Richard
    LRD414's Avatar
    Oct 2014
    Richard, I think your instinct to understand exactly what you have got now is right.
    Once you have any doubts the only way to be comfortable is to trace it all through and understand it fully for yourself.
    With the wiring diagram and discussions you've had so far, I'm sure you have enough knowledge to work it through, all the way to the plugs.
    The plugs are easily removable so as to be 100% certain about what wire goes to what pin.
    I have been through something similar with someone else's D4 (troubleshooting shoddy work) so understand your frustration but you will be better for it in the end because knowledge is power.
    Also, there is a pdf version of the wiring diagram at that other thread linked above. It is a better resolution & the only difference is the diode location.
    Regards,
    D3 2005 V8 Petrol
    Aug 2013
    ACT
    Quote Originally Posted by LRD414 View Post
    Regards,
    It good to have a place to rant.
    I am a bit lost but will look tomorrow with my son.
    The guy was in a rush but no excuse and I will be following it up.
    My son can fix the fittings and help trace the wires with me but may leave it to show them. I have to go back next week to pick up my van
    With the info gained I will be a bit better prepared
    Richard
    Kallangur, Brisbane
    They could have used a decent crimp tool to do shoddy job. They are not expensive.
    + 2016 D4 TDV6
