Results 1 to 6 of 6
Thread: Ride height settings
    Mar 2015
    Hi can the ride height auto change at 50klms be adjusted so it stays on or set to 90klms eg;? All tips welcome. 4x4instyle
    NSW SW Slopes
    The Llams kit that I produce allows off-road height and other heights to be achieved whilst at normal height and therefore without any speed restriction. The kit is plug-in for MY07-12 but hard-wired for earlier models. If you PM me your email address I'll send you information on the kit.
    Feb 2014
    also IID tool will do the trick.
    but i just went to bunnings and spent the $7 for some angle alloy and tricked the sensors to make it higher
    Nov 2005
    Maudsland, QLD
    What programming on the IID tool did you use to stop ride height from adjusting over 50 km. Would be also useful to stop ride height from going to standard height when trailer connected....not useful with an off road camper!
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Quote Originally Posted by Steinzy View Post
    This is where Llams is fantastic.. you can force it to +30/50 above standard or offroad height.
    Note the 50km/h lowering still occurs but you are adjusting standard height to remain higher...
    In conventional offroad modes with a trailer you need to push the button to get the vehicle to lift - nothing strenuous.
    Aug 2015
    Coolamon, NSW
    With the IID Tool you can't stop the 50 km/h speed restriction, all you do is make "Normal Height" permanently 50mm higher, whereas with Llams, it is at the flick of a switch, rather than having to have the IID Tool plugged in, then open the app, and set your height.
    Both methods will do what you want, but I know with having both Llams and an IID Tool, I pick Llams for height adjustments over the IID Tool any day.
    - Justin
    Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
    Moved into MY12 L322 4.4 TDV8 Autobiography
    VK2HFJ
