Thread: Shockie split pin removal.
    Oct 2014
    Northern NSW.Australia
    Hi,
    Sure I saw a home made tool for split pin removal, on a post.
    The tool is for use for a G clamp I think.
    Anyone has the link please.
    whitehillbilly
    May 2008
    Bundaberg Qld
    Made this one a few years ago from (IIRC) 25mm SHS.
    Aug 2010
    Sunbury, VIC
    Yep, made up something very similar just a couple of weeks back myself.
    Avoca Beach
    I used to just use a pair of over centre pliers and tapped them on with a hammer to unload the split pin.
    Regards Philip A
    Oct 2014
    Good stuff.
    Found some thick walled water pipe, so will make up something simular.
    whitehillbilly
    Oct 2014
    Made this today.
    yet to try it.
    Thanks for the help.
    whitehillbilly
    Oct 2014
    Shockies out.
    Are the original ones single or double oil dampened.
    3 seen to push together with little effort. But quite a bit of effort to pull apart.
    One in and out with out much effort.
    What have you used for replacements of the original type.
    Whitehillbilly
