Results 1 to 6 of 6
Thread: Steering Relay
    Oct 2014
    Salisbury Downs, SA
    Steering Relay
    Gday again all,
    Todays problem is as follows
    I have a fair bit of free play on the steering wheel, I have traced the dead spot back to the steering relay, the lower arm appears to be moving up down left and right all by itself.
    So I started doing some research, It looks like there are a lot of opinions with these.. Fix them in place, don't loose an eye with the spring, don't use bearmach, don't use reproductions, don't use reproduction kits to fix them, sell your first born child.
    Sooooooo... What the heck? where should I go what should I ask for. I saw some online from all 4x4 spares at a decent price (~200ish), but no mention of make etc.
    Now i have seen the issue i'm scared i will die :P
    Help me AULRO
    australia
    Quote Originally Posted by ozeraser View Post
    Gday again all,
    Help me AULRO
    hi i have steering relay came off a running 55 s1 kept as a spar if you need jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Narre Warren South
    Gday again all,
    Help me AULRO
    Lots of threads on repairing them on the forum.
    The aftermarket ones can have shafts that easily break hence the comments you've seen.
    Until you dismantle yours you won't know what parts are needed but everything is available and there are several methods for safely dismantling & re-assembling. Hopefully the shaft is reusable and not pitted too badly.
    Don't get the seals from a LR supplier, get them from a bearing shop.
    $200 will probably be Bearmach/Britpart as they are about 70GBP in the UK. Problem is, will yours come out of the crossmember without too many issues ??
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    JDNSW's Avatar
    Make sure it is not just the arm loose on the shaft - if so, you may be able to just tighten the pinch bolt.
    Oct 2014
    Salisbury Downs, SA
    All good thanks for the replies and offer. I got it home and jacked it up so i could get a proper look and access.
    This is what i saw...
    https://goo.gl/photos/F1PVxErAryHLvfcL6
    So i grabbed some wood chocked the arm up, and tightened the arm bolt with my beaker bar (i previously tried to do this in the work car park with a spanner not good enough ). Now shes like driving the misses fiat 500 :P
    +1 for me being an amateur :P
    Irymple, Victoria, Australia
    Good to hear some spanner work cured the problem.
    Might pay to check the oil level in it too while it is on your mind. They don't hold much, so a tiny weep over a long period can run them dry and result in heavy steering/wandering issues. With that 4BD1 grafted in there I would expect there is a few kilos to manoeuvre about.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
