Thread: 2004 NP pajero diesel
    Oct 2007
    Hi I need advice after writing off my D1 i decided to try a mitsi.
    about 3 years ago it was purchased for 20k just recently it has started hunting in idle and fluctuating in speed while driving and holding foot in same position took it to a diesel specialist and was told it is the pump which will cost $5000
    dont get me wrong it is a great car but first is this the correct diagnosis?
    secondly am I over capitalizing?
    I have never spent that much to get a car fixed in my life have always been able to fix the old D1 300tdi myself in the 6 years I had it I think i have spent max of 2000 on it and the mitsi well over 2000 in the 3 I have had it now.
    Rant over need opinions.
    thanks Rad97
    May 2008
    Bundaberg Qld
    I think your answer is obvious, but I may be biased
    Brisbane, Queensland
    Possibly sticky EGR. You could try EGR intake cleaner. I have seen pics of the intake manifold very blocked from exhaust and oil vapour.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Adelaide - Torrens Park
    I have heard that the pump is a common and expensive failure in those things.
    Nov 2014
    Nirvana near Albany W.A.
    If it's pre common rail ( which I think it will be ) then yep , it's probably pump , if it is common rail then those are symptoms of a faulty suction control valve or gummed up intake manifold butterflies
