Results 1 to 10 of 27
Thread: My fairly major driveline failure is a remote area! fun times
    Feb 2014
    boy, did I have a fun weekend away camping!
    All started off very normal, touring the VHC on my lonesome taking it easy, enjoying the great out doors. (I do this a lot)
    had a few lovely little tracks i was trying to get up, one bit was a very deep rutted hill climb that was a loose rock and mud construction. I think I did well to get as far as I did. but i just couldnt get that little bit further.
    So after a few runs i tried to do something silly!
    I had seen where people use a snatch strap fixed to a spinning wheel and then anchored to a tree and use the car to winch itself forward.
    Turns out this works...just not with an l322 with fantastic traction control systems, 500nm and on such a difficult incline! haha
    it pulled me forward a little bit, then suddenly she all went pear shaped! click click bang! absolutely destroyed the front right half shaft (Where i had put the strap onto) I had go out to take a look knowing full well what happened....but i was shocked to see engine oil leaking from the rear of the engine!
    after a long effort and chaining the front driveshaft to the subframe, i managed to get it out to a suitableish spot and onto a trailer and home (Big thanks to my mate for doing the 13hour return trip)
    I now have it all apart and waiting for parts to arrive.
    Damaged Report:
    Front half shaft twisted apart! The cv is still in working order! i was impressed with this one
    Next, the engine oil leak. tracked it back to the sump being cracked! Not even a little crack!
    After a bit of detective work, ive concluded that the bolts that hold the diff in place (4 of them) were loose. I had come across this before and tightened them previously. but it must have come loose again. im sure this extra movement allowed the shock force of the axle snapping to cause the sump to crack also.
    And in my attempt to get it out of the bush track and into a recoverable area, I managed to damaged the transfer case to some extent. I will strip this down once the front subframe and engine is back in its mounts.
    Just waiting for the sump and half shaft to arrive today or tomorrow. and bobs your uncle.
    Good news, if anyone wants me to check or find out more information while i have these parts out, speak up now! ill be opening the diff tonight to take some measurements for the possibility of some locking centers. etc
    Also, the diff can be removed (with some decent jiggling) while the engine and subframe are in place. Workshop manuals say to have it dropped for the removal.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Crikey, some one didn't read the Land Rover warning label on the door pillar that warns against , using a snatch strap on the front wheels to winch the vehicle out.
    Jul 2010
    Victoria point
    Thanks for sharing Chaybra. I had to unload my sins on this forum a couple of years ago when I tried something stupid with my D2. We all learn from mistakes, either our own or others. I guess you won't do that again. Good luck with the repairs.
    Feb 2014
    Crikey, some one didn't read the Land Rover warning label on the door pillar that warms against , using a snatch strap on the front wheels to winch the vehicle out.
    Hahaha wish i saw that one! I just need a winch
    Wraithe Guest
    Chaybra,
    If you have bolts coming loose or know of ones that will vibrate out, look for a product by "Loctite" called "Super Wick in". Works magic on holding bolts and you can easily work them after, ideal on adjustment bolts were you need to move occasionally..
    Great on any vibrating machine, crushers, balers, Headers, and the old bombs we use around paddocks.
    Feb 2014
    Quote Originally Posted by Wraithe View Post
    Chaybra,
    Ill be fitting spring washers when she goes back in!
    NSW SW Slopes
    Did you wrap the strap around the wheel or the drive-shaft?
    Feb 2014
    The wheel, the intention was it was like it would be driving normally but with full traction.
    however, being the only wheel with traction, the TC system allowed that wheel to get 100% torque
    Brisbane, Queensland
    So it might have worked with a strap on both front wheels?
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by rar110 View Post
    That's what I was thinking.
