Results 1 to 6 of 6
Thread: Screw needed!
    May 2003
    On The Road
    Screw needed!
    well, actually I need 16
    This QNAP (TS 439 Pro II) I happened across has empty HDD trays, unbelievable huh.
    The pic shows the normal PC screw first and third and the countersunk screw second and forth,,
    BUT!
    the head of the countersunk shown here is too WIDE!
    When bolted up it sits proud of the tray and stops insertion into the machine.
    The one in the tray was just luck!
    Anyone have any stored away?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    so it takes 2.5" hdds by the looks of it?
    if so, i'll have some here i would imagine from wrecked notebooks..
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2016
    Country Vic.
    Quote Originally Posted by incisor View Post
    Either 2.5's or 3.5's.
    Looks like Pedro is using 3.5's.
    Sorry Pedro, I have none(or maybe one single solitary screw.
    They just use any normal countersunk HDD screw. I think they should be M3 x 4mm.
    They aren't any special or particular type
    (unlike this annoying USB enclosure I have that's about to get chucked).
    EDIT: ps. I just bought a pack of 25(I need some too) off ebay for $2. In my search, I found none available locally in Aus, so just went with the cheapest from China(I'm in no rush).
    Just do a search(on ebay) for "countersunk hard drive screw" and you'll get a million and two hits, and they all generally say hard drive caddy screw(which is what you want).
    May 2003
    On The Road
    yes Inc,, the screws holding the side brackets are the correct thread,, but just not enough of it-- something strips before it gets anywhere near tight--
    I can buy them from QNAP,,
    bag of 96 for $32 plus freight--
    May 2003
    On The Road
    I wonder what the ramifications are of countersinking the hole bigger??
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    if it were me i would be filing the heads down..
    not as if they have to be tensioned to 200ftlb
