Results 1 to 10 of 22
Thread: Win 10 digitel licence?
    May 2003
    On The Road
    After my cataclysmic PC failure windows now tells me my version is not activated,, which it does when a major hardware change occurs.
    As all my records are now toast how do I convince Microsoft my Win 10 is legit?
    Apr 2016
    Country Vic.
    If you change just a HDD, or a motherboard, or (I think) up to about 4 other pieces of hardware, you shouldn't have a problem.
    If you changed more hardware .. which amounts to basically a new PC, then you're going to need a new licence.
    You're data shouldn't be toast(as such) .. it'll just be locked into that Win install for a while until you can transfer it over to another device.
    Windows is only licensed for use on that machine(pre catastrophic failure).
    What hardware did you change?
    Kippa Ring
    With W7 you could get loaders which are programs that activates windows. Maybe search around for one for W10.
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    95 Disco v8 - The Next Victim
    Jatz Guest
    Just get on the phone to Microsoft. I've done this a couple of times in the past.
    Just tell them you had some hardware fail on your computer and after replacing it Windows doesn't activate, they'll give you a code to enter (really long one) over the phone.
    May 2003
    On The Road
    well, seeing "it" took out my power supply, motherboard, video card, and 3 HDD's I just bolted the SSD(C drive) into a different PC.
    I am seriously amazed it survived.....
    Ok,, phone call coming up.
    May 2003
    On The Road
    so its now officially a 95% perfect storm.
    only needed the ssd to die for perfection.
    Microsoft could not find my win 8 key,,
    I asked Swetha to search THEIR records for my payment,,
    "not my job. try here"
    used belarc, winkeyfinder, (why doesnt she know where it is?) winkeyfinder came up with a key, but not the correct one-- just how many keys are there?
    and, believe it or not. YOUR microsoft account doesnt have ANY info relevant to the legality of your win 10.
    so whats it for?
    apart from gathering more info---
    how much Inc?
    65?
    Apr 2002
    Bellara 4507
    32.43 MB
    Will pm you the source..
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    On The Road
    I have now upgraded the storm to 100%..
    SSD corupted, at some stage while still visable I loaded hirens and copied 100 odd gbs to another drive.... of course the windows recovery disc wont recover, and the iso loads till a purple screen and stops. mouse, headphones and keyboard lights all go out.
    Have just finished running seatools on the ssd and it passes everything ?????
    am now waiting for the PC case to fall apart....
    May 2003
    On The Road
    just wondering if my install failure is to do with formatting???
    the iso works, it runs fine until a drive is connected-- then freezes.
    May 2003
    On The Road
    it seems to just time out,, tried a usb install this time,, just freezes up...
