Results 1 to 6 of 6
Thread: Series Rim ID
    Irymple, Victoria, Australia
    Series Rim ID
    I have a varied collection of standard rims and would like to know on what series vehicles they were originally fitted?
    272309 riveted 35mm positive offset.
    272309 plug welded 40mm positive offset (distinct 5mm difference in offset to the riveted rims)
    FV2000727 20mm positive offset
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Narre Warren South
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    the two with numbers 272309 are meant to be the same part, with the welded ones later (or possibly different supplier) to the rivetted one. The 5mm offset difference should be considered manufacturing tolerance - I think they are meant to be 1 3/8"or 35mm!. These are standard on Series 2/2a 109, optional on 88, also supplied with all except late production Australian manufactured Series 3.
    I don't recognise the other number, although I think I have seen it before.
    FV part numbers are Fighting Vehicle part numbers. It might make that wheel originally a British army Land Rover wheel.
    Aaron
    Quote Originally Posted by Aaron IIA View Post
    Aaron
    Aaron,
    are the "FV" a heavier grade of rim?
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    Feb 2013
    Sunshine Coast
    Quote Originally Posted by mick88 View Post
    Are you sure they don't have NRC7578 stamped on them as well? Usually they do and they are the generic 110 (pre-Defender) rim.
