Results 1 to 8 of 8
Thread: Air Con fitted to 110
    Feb 2014
    Queensland
    Just has a very neat install done on the 110, due to having a 200TDI Disco engine there was little bit more work to be done than a standard engine, all in all a great job, looking forward to testing out when it arrives here.
    Jan 2010
    Tidy 200tdi conversion that. Do you have a pic of condenser + fans mounted? Good to see they didn't give it a puma nose and kept the grill inline with lights!
    Feb 2014
    Queensland
    Quote Originally Posted by manic View Post
    I will ask if they have pics of the install.
    Irymple, Victoria, Australia
    Was it originally a 4BD1?
    If so may I ask why the engine change and how is it?
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Feb 2014
    Queensland
    Quote Originally Posted by mick88 View Post
    Cheers, Mick.
    Hi Mick
    It originally had a 2500cc NAD engine, as per UK MOD spec, Glencoyne Engineering Ltd did the 200TDI conversion, I have only had a short drive of it in the UK, so can't really say how good or bad it is until it arrives.
    Feb 2013
    Sunshine Coast
    All 200 and 300tdis with aircon have the flat grille surround. It should be a simple matter of fitting factory bits, although the Disco 200tdi is different to the Defer version.
    Jan 2010
    Quote Originally Posted by Dervish View Post
    True, except I found the tdi fans are way to big to fit on my TDI conversion from na . Even though I am using TDI radiator position. How they fit it all in on a 200/300tdi defender factory install is still a mystery to me, not seen one behind the grill.
    Feb 2014
    Queensland
    I will post pics when it gets here, but I do know the fan is a slim unit, so it fits the standard nose cone. I have another kit on its way soon to go in the V8, this will be a AU install.
