Results 1 to 10 of 12
Thread: Oil leak and losing power
    Nov 2014
    Sydney NSW
    Hi guys,
    So as some know i am currently doing the ocean rd with the family.
    Ive posted some egt results and everything has been going fine, however today i noticed some oil leaks the size of a 5 cent piece on the floor under the passenger side.
    On closer inspection seems to be coming from the front of the engine near the water pump. I own a 2.2 110.
    Driving today i noticed that at 100kmph im losing power and in fact the car started to loose revs and would not maintain speed. Normally my car pulls like a train and maintains low EGT's.
    Any ideas?
    Jan 2014
    Perth Western Australia
    On the passenger side, the last intercooler hose before the intake, they commonly get a small split on the bottom (can be seen with a mirror).
    BUT, normally there is a increased induction sound and the engine light comes on...
    Daz
    Daz
    Nov 2014
    Sydney NSW
    Quote Originally Posted by DazzaTD5 View Post
    Daz
    Hi Daz,
    Thanks for the reply. Its definitely not the cooler hose as i have an Alive cooler and after market hoses. Im thinking the brake vacuum pump or the seal for the high pressure fuel pump on the front of the block???
    Sent from my SM-G925I using AULRO mobile app
    Jan 2015
    How did you go with isolating the problem?
    pd
    Nov 2014
    Sydney NSW
    Quote Originally Posted by dazzler View Post
    pd
    Hi Dazzler,
    Looks like its coming from behind the inspection panel on the front of the block behind one of the timing pulley brackets.
    Im going to try and make it back to Sydney and hopefully get Graeme Cooper to look at it.
    Whatever it is it is affecting my acceleration expecially in 5th at 100kmph up a hill for example. The funny thing is that if i put it into 6th when its struggling in 5th it starts to pull again, be it with some vibration as my tune makes a lot of low down torque.
    Jan 2015
    Hi Mate,
    I hope it is not too bad, how is the engine/egt tracking? Good Luck!
    pd
    Nov 2014
    Sydney NSW
    Hi Mate,
    pd
    Thanks Dazzler.
    Egt seems normal. I check the oil and coolant 3 times a day and all seems ok. I might top up the oil a little before heading back to Sydney (miniscule amount). Its just annoying cause all the mods I've done have made the truck run like a dream and now im babying it cause of a tiny little oil leak.
    Anyway i look at the bright side, i can start to prepare it for Cairns later in the year.
    Nov 2014
    Sydney NSW
    Also this leak is affecting my air con to the point where it isnt even cold. Any ideas people?
    Marty90 Guest
    Maybe the air-con compressor has crapped itself? just a thought.
    Nov 2014
    Sydney NSW
    Quote Originally Posted by Marty90 View Post
    Hi mate, im pretty sure it has to do with my oil leak. Ive read a leaking vacuum pump can affect the air con and its leaking in that area
