I don't tow, but cooling is always back of mind. I am replacing existing HID's (where you have the round intensity's) with following:
ARB 4?4 Accessories | order)
Also thinking about replacing the Driver side wingtop access panel cover with a vent "facing rearwards"
Additionally thinking about fashioning some sort scoop/underbody plate to channel underbody airflow upwards to the engine/Gear box etc )bit of f1 tech for the landy
pd
 and could fold the metal in such a way it will deflect the air upwards into the sump/gear box area, this will also help the heat displacement from under the gearbox tunnel.
