Results 1 to 10 of 26
Thread: GOE Height Sensor Rods
    Jan 2017
    As many of you know, GOE sells Height Sensor Rods for an affordable "lift kit" alternative for D3s D4s RRs etc... However there are a couple of things on their website that confuse me a little bit. Such as a paragraph that says that replacing the height sensor rods is not recommended for long drives and that people have destroyed their CVs after as little as 600kms (link to webpage: Green Oval Experience Land Rover training, Range Rover modifcation). I'd love to get the opinion of some more experience LR owners.
    Basically, as with all suspension lifts, this product forces the CV joints and airbags to work harder than normal. What I'm wondering is if there is anything to worry about?
    Does anyone use these products and has anyone had bad experiences. Alternatively, has anyone had some great experiences with sensor rod replacements long term?
    Background: I plan to cross the Simpson Desert in June/July '17. Having the extra clearance over days of sand driving would be an excellent improvement.
    Thanks for all your inputs!
    Williams West Aust
    The rods have a standard height hole,so you can use the extended height where you need it and revert to standard after.
    If you are going outback have you got a decent fault diagnosis reader???
    If not look at a Idtool.It will do all the height raising/speed raising etc plus you have the diagnosis tool.Cost is similar to the Llams.
    This group buy is closed,prices are similar due to AUD fluctuation.
    IIDTool Bluetooth group buy.
    Plenty of info here.
    https://www.aulro.com/afvb/verandah/...-firmware.html
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jul 2010
    Australia
    Hi
    I have used the Rods on the off road setting crossing the Simpson as well as on all High Country trips. I set them back to normal height when doing highway speed. I hardly exceed 60 kmph when I am on the off road setting. Never had problems with CV nor damage to the driveline.
    Gordon can inform on this, but I think the main issue is when you drive at highway speed with the rods on off road setting?
    GD 4
    Jan 2017
    Very interesting, that sounds quite good. Looks like an extremely detailed tool.
    Thanks.
    Mar 2016
    I use the All Height feature of IIDTool to achieve the same effect electronically. Takes 30 seconds - plug in, set value, unplug.
    2007 Audi RS4 (B7)
    Nov 2014
    Nirvana near Albany W.A.
    X3 on the gap iid , Bluetooth version is worth the extra , and as LandyAndy pointed out , you really want a diagnostic tool on a trip like that , duckworths do a really good price on the BT version
    LRD414's Avatar
    Oct 2014
    I agree regarding the iiD tool and have a BT one myself.
    I also have Llams to take care of height control with even more convenience than the iiD tool.
    However, regarding your original question about vehicle damage .....
    Leaving your vehicle at higher than normal ride height for extended periods at high speed will lead to reduced lifespan on CVs, etc.
    This has nothing to do with how the height is set (rods/iiD/llams).
    But the slower speeds offroad such as Simpson or VHC or whatever will not be as severe.
    But even then I always go back to normal height whenever it's practical to do so and this is the real advantage of Llams.
    It is so easy and quick to change height without stopping and/or looking at any screen.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    What they're saying is if you get the IID tool don't get the rods
    Just to throw it in the mix. I don't do Sand as a rule at +50.
    I run at +30mm using Llams (which is in cab adjustable)
    Brisbane,some of the time.
    I ordered the rods before a Simpson desert trip,and they didn't arrive in time.
    I did the trip,across and back fully loaded, no problems at all without them.
    Jul 2010
    Australia
    Hi
    The official speed where the Disco 4 goes from Off road to normal height is 50 kmph as per handbook. I noticed that it automatically changes around 55 Kph in practice. So the LR spec is that up to 50 kph is OK on off road height
    GD4
