Thread: Wanted to borrow - 23mm or 1/2" Whitworth Open end spanner - Melbourne
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    The name of the thread says it all - I need to borrow if at all possible an open ended spanner that is 23mm or 1/2" Whitworth - either will be close enough. 7/8 is too small and 15/16 is too big and looks like it will damage the fitting and slip if I try too hard. There is no room to get a shifter, vice grips, stilsons, etc in there without removing a lot of stuff, so if anyone in the Melbourne area has one I can borrow it would be greatly appreciated.
    I only need to undo one fitting so I can get it back within 24 hours. Can pickup pretty much anywhere in Melbourne.
    Thanks in advance.
    Apr 2011
    Wandong,Victoria,Australia
    Hi Gav,
    I *think* that I have both...
    Is that what you are after?
    GG.
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    australia
    Quote Originally Posted by Homestar View Post
    Thanks in advance.
    hii you need a half inch in your tool box if you get no luck i will post one too you i will be at toowamba swop if you come up then it will be free jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by grey_ghost View Post
    Hi Gav,
    GG.
    Certainly 1 is right, as discussed on the phone, I'll swing past and grab them tomorrow - thanks heaps.
    Quote Originally Posted by russellrovers View Post
    Thanks for the offer Jim, looks like I'm sorted.
    Cheers.
    Feb 2013
    Ballarat,Vic,Aus
    Next time your at the sunday markets... have a look around for the cheap spanner sets that step from 6mm -> 32mm. They are worth there weight in gold. The quality is actually ok'ish and there so cheap you can modify/cut/bend them as required.
    It's amazing how often I've used the weird size spanners with land rovers and citroens here.
    Oh, mine was missing 31mm (I didn't realise they had included two 30mm instead)... so double check all the weird sizes are there
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
