Results 1 to 10 of 14
Thread: td6 transmission valve body
    Jan 2017
    Does anyone know the differences between the Commodore and Rangie valve body's?
    Have a good trans from an Adventura that ive been robbing parts for mine and would like
    to swap it over
    Kingston, Tassie, OZ.
    Should be interchangeable between 5l40e. Best ask Rhys at Furious Performance. He is a 5l40e guru.
    Jc
    Feb 2014
    Quote Originally Posted by TJK2002 View Post
    Hi.... just posted in wrong section so I will try again
    Is there a difference between Rangie and Commodore valve bodys?
    As I have an Adventura box in good order that ive been robbing parts for mine
    And would like to use said valve body
    Tough question, you may have to track down a gm transmission specialist and ask them.
    I don`t know , seems they physically fit but may not drive as desired .
    The link gives plate numbers to application .
    Seems the obvious difference between early and later is early has a larger black Holley solenoid and later has a smaller silver Bosch solenoid .
    5L40/50-E Valve Body Identification - Sonnax
    Jan 2017
    Ok have had them side by side when box was apart a few months ago physically look the same apart from the accumulators didn't do a number check
    I'm actually using the Commodore accumulators at the moment seems to give a more firmer shift!
    My reverse at moment is delayed and im hoping its the valve body
    Aug 2010
    Sunbury, VIC
    As Justin said, Rhys in the Guru on these boxes. I'll shift this thread to the L322 forum as well.
    Oh, and just merged them as I didn't realise youd started again here.
    How much of a delay? Wirse Worse hot or cold?
    Jan 2017
    seems to be there all the time... hot or cold..
    Am going to monitor it over the next few days,
    This trans had burnt the reverse clutch at around 100thousand ks
    pulled pan (never been opened) replaced oil (black & burnt) and filter drove for another 40k working not to bad till the front drive shaft stripped its splines
    Has taken a while till I was in a position to put back together
    Have replaced all clutch packs, seals & pressure control solenoid.
    Clutch pistons all tested ok, all bearings and shims ok.
    torque convertor when opened was just about to go metal to metal
    replaced with HD unit 400 rpm lowered stall.
    also installed Sonnex boost valve
    Feb 2014
    what year model is your car TJK2002?
    Feb 2012
    Parkdale, Melbourne
    I'm gonna take a stab in the partially lit room and say 2002! :P
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
