Results 1 to 9 of 9
Thread: front diff replacement
    Jan 2017
    Hi all
    My Rangie being in storage had missed the recall on the dreaded stripped prop shaft replacement
    after many a long night trawling the net, lots of inquiries and miss information
    (was told that you simply change input coupling whilst diff in position and use later prop shaft) didn't seem right to me but people supposedly in the know convinced me
    Anyways rang local wrecker on availability of parts whom had a prop shaft from a V8 (same part numbers) and then totally confused him and me over the input coupling replacement
    Was advised to give wreckers in Adelaide a call and after much discussion and a return call was advised to replace complete diff
    Placed order for diff and it arrived the next day complete with said input flange
    Now the fun begins
    Rave advises to hoist motor drop subframe etc etc etc
    Must be a better way...
    dropped pressure to front bags
    unbolt calliper, disconnect brake sensor & wheel sensor
    remove level switch
    disconnect torsion bar
    loose swing arm bolts
    pop axles out of diff
    undo mounting bolts for rack and tie rod... push rack up
    remove bolts bottom of strut
    drop swing arm down axle will follow giving you plenty room to squeeze
    diff out and new one back in again
    'Note'
    Just remembered you will have to disassemble drivers side as well to get axle out enough for diff removal
    Mar 2007
    You have done a great job on the repair
    Just curious; did you approach Land Rover Australia ? I would have at least tried, it was a known / recalled fault. Surely LR would have budgeted and arranged parts for all Australian delivered cars. Not sure on the Consumer Act regarding this !!!
    Laurie
    Jan 2017
    Quote Originally Posted by Laurie View Post
    Laurie
    Yes did approach them.... was told that the recall was not on anymore
    This is where I started to get the miss information on how to fix
    In the end I was running short on time and the whole job cost around $600 and approx. 3hrs to do could do it quicker now I know what to do
    My original diff had been changed in an earlier recall by the look so should be
    low ks would like to replace the input if anyone has a damaged diff they want to offload
    Cheers Terry
    Feb 2014
    Looks to me like you only had to change the coupling on the diff...not the entire thing.
    Jan 2017
    Quote Originally Posted by chaybra View Post
    Yes that is correct... could not get one from anywhere other than genuine Cost was more than I spent in total
    Feb 2014
    Quote Originally Posted by TJK2002 View Post
    How much fun did you have trying to get the cv spindles back through the wheel hubs?
    mine were very tight and took a long time with a ratchet strap and some banging on the hub
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Under $400 for the kit Genuine.
    Jan 2017
    Ok... Cool may talk to you soon if I don't get a second hand one
    Does that include crush bearing?
    Diff cost $460 inc delivery plus prop shaft, drive shaft seals, oil and sundries
    Cheers Terry
    Jan 2017
    Didn't need to pull cv's out of hubs not looking forward to that when time comes
    Had trouble with drivers side getting axle to seat
    Splines lined up ended up block of wood and hammer went straight it 1st hit should have removed cv boot 1st
