Results 1 to 10 of 12
Thread: Suspension bolts
    NSW SW Slopes
    Suspension bolts
    When changing LCA bushes or even just getting an alignment, if the nut is tight enough due to rust then the bolt can shear requiring a replacement bolt before the vehicle can be driven again. Best to have spares on hand even if not intending to replace them.
    Always replace - they are torqued to 290nm so play it safe!
    And some copper anti-seize on the new ones Suspension bolts
    Ellendale Tasmania.
    We carry them just in case, will have ours replaced before we do our big trip in July.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Jan 2015
    LR part numbers
    Bolt RDI000034 Nut LR025050
    Washer (presumably rarely needed) RYF000203
    right?
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    NSW SW Slopes
    The nuts are also squashed as a form of locking mechanism so it doesn't take much rust to prevent them from undoing. However I was surprised that a 3/4" drive socket could break the bolt using only about 600 mm leverage, albeit with another spanner on the head to hold the bolt still.
    Jun 2010
    Central Coast NSW
    Quote Originally Posted by l00kin4 View Post
    LR part numbers
    right?
    David
    I bought bolts and found the old washer didn't fit the new bolts. They cost about 2 bucks so i wouldnt risk it!
    Aug 2015
    Coolamon, NSW
    Yeah, was quite a shock for it to go. The dirt in the break is from dust falling onto it, not an existing fatigue indicator.
    All the other bolts were in alright condition, still had their position (F Right, Robert Left etc) still hand written on them from last bush change.
    - Justin
    Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
    Moved into MY12 L322 4.4 TDV8 Autobiography
    VK2HFJ
    Aug 2015
    Coolamon, NSW
    Quote Originally Posted by Disco-tastic View Post
    My old washers fit fine to my new bolts, but I can see if they had enough corrosion they would be difficult to fit.
    - Justin
    VK2HFJ
    Dec 2009
    Ranelagh, Tasmania
    I replace bolts and nuts each time due to the high torque value. I also use an anti-corrosion paste on both the bolts and threads. The washers from the old bolts fitted on the new bolts.
    My old bolts showed no signs of corrosion, I would use them again in a pinch.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Aug 2015
    It didn't feel right putting that extra long, highly torqued bolt back through the lower air strut/shock assembly either.
    Just a shame I didn't consider it until they were undone and not when ordering parts.
