Results 1 to 10 of 11
Thread: HDC tans faults while driving on beach
    Jul 2012
    Toogoom, QLD
    Okbrains trust question for you.
    Lasttwo beach trips I have had several HDC transmission faults kick in. Vehiclegoes into limp mode and lowers. Stop.
    Turnoff and lock unlock 3 times clears it.
    Sandmode on, DSC OFF. does it in either high or low range.
    Interestinglyif I leave DSC on it does not present. Or doesn't yesterday.
    Codesdon't reveal anything of interest.
    Brakeswitch??
    Transmissiongetting hot?
    Wasn'tpushing that hard. About 2000 RPM. High range to start with in 2ndthen went to low range and auto.
    Samefault presented.
    thanks in advance.
    Oct 2012
    Quote Originally Posted by PeterOZ View Post
    Brakeswitch??
    thanks in advance.
    For under $40 I replaced the brake switch and brake globes and problem went away (so far). It's starts at HDC and cascades to Transmission then Suspension Lowering.
    Jul 2012
    Toogoom, QLD
    Quote Originally Posted by PerthDisco View Post
    Thanks pretty much what I thought. I'm getting new brake light switch on Friday.
    Just replaced twice RHS brake light. I normally run the Phillips globe but could only get SCA which are rubbish. Will call into Repco and grab some Philips ones.
    Williams West Aust
    Peter.
    A W4 member reported the other week he had issues with cruise not working.Replaced a faulty brake light with a non genuine but reasonable quality globe,still no cruise.Fitted a genuine globe and it fixed the problem.
    Was a D3.
    GOODLUCK
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jul 2012
    Toogoom, QLD
    Peter.
    Was a D3.
    GOODLUCK
    Andrew
    what brand is genuine? Phillips?
    Williams West Aust
    Cant help I'm afraid.
    Andrew
    Jul 2012
    Toogoom, QLD
    all good, got onto a contact LR parts up here and he is checking with the workshop boys. He did say they have the OEM LR globes but are expensive.
    No kidding sherlock hahaha
    I was reading in some threads on other forums that the LR globes are a higher spec filliment which maybe is why they upset the canbus when you put lower spec globes in or they fail.
    Just summising so don't shoot me.
    Feb 2010
    Put LED globes in my 2005 SE years ago. Love them. Well worth considering.
    Mar 2015
    Engadine
    Quote Originally Posted by NavyDiver View Post
    Did the same. I explained the temprementality of brake lights on Discos to my local automotive parts store and they were prepared to let me return the LED globes they sold me if they played up. Two years later and still no problems.
    Oztourer
    MY05 TDV6 HSE, Buckingham Blue
    Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
    Jul 2012
    Toogoom, QLD
    Where from? Got a part number or any details on them?
