Results 1 to 10 of 21
Thread: Tubed and tubeless 3 spoke alloys
    Oct 2011
    Sunshine Coast
    Does anyone know the difference between the genuine LR RRC 3 spoke alloys in tubed, and tubeless? I have an old set marked Tubed - but see that later ones are tubeless. What's the difference?
    WA
    As with all tubeless rims, there's a little "hump" running around the circumference next to the bead. It's supposed to help keep the tyre on the rim if it goes flat, whereas I guess the idea before was the tube would do that.
    I've got tubeless three-spokes on mine but tubed for the two spares because I still haven't found some more tubeless rims. I don't like this because modern tyres aren't supposed to have tubes inside as they can rub through from the rough interior of the tyre and go flat.
    At any given point in time, somewhere in the world someone is working on a Land-Rover.
    Oct 2011
    Sunshine Coast
    Yeah that's my worry. Fitting tubes to modern tubeless Tyre and having Tyre wear holes in tube.
    Williams West Aust
    The tube welds to the ribs in the tubeless tyre causing a failure on the tube.
    The tyre will go flat,but not instantly like a blow out.
    The trick is to put LOTS of talcum powder in when mounting the tyres,it helps.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    May 2012
    Dalyellup
    Quote Originally Posted by Davo View Post
    I have 3 RRC tubeless 3 spokes in Bunbury if you want them.
    WA
    Certainly! I'll send a PM. Thanks.
    WA
    Not An Abba Fan, did you ever get the PMs I sent?
    Oct 2011
    Sunshine Coast
    I picked up a full set from British Offroad and they took my tube style rims
    Aug 2010
    Sunbury, VIC
    I don't have the details handy, but there are tyre manufacturers that state in their literature that their tyres can be fitted to tube type rims without tubes - I was shown this at a car show a couple of months back, but can't remember which manufacture, or what tyres it referred to - it did relate to their Australian offerings so I would have thought if the tyre manufacturer was happy to do this, there shouldn't be any issues . While I know this has been discussed in great detail before, I haven't seen any documentation to say doing this is actually illegal (although I'm happy to stand corrected). I run the tyres on my trailer tubeless on old series rims, but not currently with any vehicle, but I will be soon - it will be going through a proper roadworthy eventually, so I guess I'll know then for sure...
    Just a thought.
    Quote Originally Posted by Meccles View Post
    Tubes and Tubeless - A Guide | LandyZone - Land Rover Forum
