Results 1 to 10 of 11
Thread: Water Leak
    Nundle
    Water Leak
    Took Leon out to our monthly LR gathering in Tamworth yesterday and most of the water decided it didn't want to circulate anymore, so it escaped via a perished and split top radiator hose.
    One of the blokes (thanks Rick) offered up some silicone sort of self amalgamating tape. This, along with a couple of strategic cable ties, got me home albeit most of the way on 3 cylinders, closely followed by Grant (thanks). This, I assume, due to wet dizzy and or plugs, which cleared itself a couple of k's from home.
    Now to chase up a new one or a similar replacement. And some tape for the spares box. First time in over 10 years, he's given any real grief.
    Numpty
    REMLR No 143
    Narre Warren South
    Take the old one with you to Supercheap go through their stock and you'll find one that fits (may have to cut it down).
    I did that with mine years back and I think it was one from an early Corolla that fitted, I did write the details down but can't find the bit of paper now !!
    OK, found an invoice from 2008 ! The hoses were from Supercheap but the brand was Grommet (!)
    GR94/CH1338 top hose for a Toyota Corolla 1.3 1980-84
    http://www.ebay.com/itm/TOP-RADIATOR...BV5BCE&vxp=mtr
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narrogin WA
    Nice one Colin!
    Will it fit the 1600cc engine?
    Cheers Charlie
    Narre Warren South
    Quote Originally Posted by chazza View Post
    Nice one Colin!
    Cheers Charlie
    Charlie, I don't have one so can't comment..... are the connections on the radiator & thermostat the same diameter as for the 2 litre ? If so it probably will fit.
    Supercheap have all the hoses out on display so you can poke around till you find something suitable. Most other places you have to get the person behind the counter to look for you and most people aren't interested.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Irymple, Victoria, Australia
    Today at Bursons I see that McKay Rubber do universal Zeds and bends.
    http://www.mackayrubber.com.au/pdf/Universal_hose.pdf
    450 & 900 HOSE BENDS
    Mackay 45? & 90? Universal Hose bends are available in two specifications, one is suitable for Water applications and the other is suitable for Fuel and Oil applications.
    45? & 90? UNIVERSAL HOSE BENDS - WATER
    The 45? & 90? moulded water hoses are suitable for plain water and automotive coolant applications.
    Manufactured using an electrochemical degradation (ECD) resistant EPDM rubber tube, lock-stitch knitted Rayon fibre reinforcement, with an EPDM rubber cover for heat and ozone resistance.
    Sizes 8mm to 19mm ID Exceed Heater Hose Specification SAE J20R3 Type EC Class D-1 and D-2
    Sizes 25mm to 63mm ID Exceed Radiator Hose specification SAE J20R4 Type EC Class D-1 and Class D-2
    Working Temperature Range: -40?C to 125?C (-40?F to 257?F)
    CAUTION: Not suitable for fuel, oil transfer or brake fluid applications.
    Cheers, Mick
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Nundle
    Quote Originally Posted by gromit View Post
    Top Radiator Hose for Toyota Corolla 1 3L 4K C 80 84 CH1338 | eBay
    Colin
    Nice one Colin. Although that does say it's 32, which I presume is 32mm
    I went everywhere but Supercheap yesterday.
    Biggest issue is size, as most hoses are a lot bigger these days. The Series 1 2 litre is 1 1/8" (around 28.5mm) Plenty of right angle bends around, but all bigger than that.
    Before I order a genuine one I'll make a trip to Stupidcheap.
    Nothing to suit in Bursons here Mick
    Perry
    Numpty
    REMLR No 143
    Narre Warren South
    Quote Originally Posted by numpty View Post
    Perry
    Perry,
    That hose fitted my 2 litre OK and there was another I purchased at the same time GR13/CH935 which I think was the lower hose. Or maybe it was the top one......too long ago to remember.
    The advantage (?) with SuperCheap is that you can rummage through the hoses yourself.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narrogin WA
    The 1600cc engine is 1 1/8" as well.
    How did the orange self amalgamating work out.
    I carry rescue tape supposedly designed for the purpose you used it for in my spare parts but have never used it - until the other day when my garden hose developed a small puncture hole so I used the tape on it - twice - it failed on both counts with the house water pressure causing it to bubble and let the water out. Maybe it will work better with the heat of you coolant rather than cold tap water.
    My experience has me thinking I might need to rethink but seeing your experience has me thinking again.
    Nundle
    Garry, that stuff worked a treat. Mind you, I only had to drive 11k's home. and I put the cable ties on just for peace of mind.
    When I was in Bursons with the hose, a bloke was admiring my fix and told me a mate of his had used it on a repair and left it for 10 months without issue.
    Me, I'd only use it for emergencies and like you, thought that 100mph tape would be the go. There are good and bad brands of these too.
    Off to Stupidcheap now for a looksee.
    Perry
    Numpty
    REMLR No 143
