Results 1 to 9 of 9
Thread: VIN confussion
    Jun 2016
    Wide Bay
    VIN confussion
    Being a Landy newbie I am confused, easy to do I know. I believe I purchased a 1955, 86" Series 1 Land Rover. I was just making an order for some parts and the supplier has asked for a VIN # (obviously to prevent mistakes by people like me. I went outside to check, as I have never bothered before and found a number stamped on the left front spring mount. I can not find and other numbers at this time. The number stamped on the chassis is 1177.
    I checked here, https://www.google.com.au/url'sa=t&r...jT94QME0mxv8Pg and the best I can figure is my chassis is from a Home RHD 88" built in 1957. Problem is my chassis was from here in Australia and is definately an 86" model. So, can anyone help??
    RIVERLAND, SOUTH AUSTRALIA
    Quote Originally Posted by grazza53 View Post
    86" 1954 SWB S1 - Chassis # location
    Have a look through this thread it may assist,,
    May be worth getting to the area under those 4 numbers as the chassis number wasn't all that deep, looks a bit
    Like bottom of a 6 on the right hand end there? Give it a good wire brush or even better sand paper so as not to damage it
    Jul 2009
    S.E.Qld
    What makes it "definitaly a 86" model" ?
    .W.
    If it is a home market model, the number should be on the RH front chassis rail. If it is Australian, it will be on the LH back rear spring hanger. It is possible that the number you have is a number assigned by a local authority*, but in this case, it should have a letter prefix such as 'Q' for Qld, 'N' for NSW or 'VP' for Vic. Police. I would clean up the area around the number you have, and also look for a number in the other locations.
    Just as an aside, VIN did not exist for Series 1 - this was introduced during Series 3 production. The number on earlier Landrovers is a chassis number, and is not unique, only unique to the particular model or manufacturer.
    *Local authorities will assign a number to a vehicle when the original number cannot be found or when a 'one-off' is constructed.
    Jun 2016
    Wide Bay
    Quote Originally Posted by B.S.F. View Post
    .W.
    As the vehicle sits now it has an 86" wheelbase. I can not see anywhere obvious, at this stage, where the wheelbase could have been altered.
    I will have a bit more of a dig around tonight (to hot outside just now) and see if I can locate any further numbers.
    Jan 2013
    Molesworth,Tasmania
    Can you put some pictures of the vehicle up Mate - theres a few people on here that can probably tell you what it is just by looking at it!
    D
    1957 88 Petrol (Chumlee)
    1960 88 Petrol (Darwin)
    1975 88 Diesel (Mutley)
    Jun 2016
    Wide Bay
    Well the front mudguard is 86".
    Sep 2012
    Westlake ,brisbane
    The chassis number should also be stamped on the transfer leaver plate on the bulkhead just infront of the leaver.
