Results 1 to 3 of 3
Thread: Piranha Battery tray does not fit on disco TD5
    Good day all,
    I bought a dual battery tray from piranha (BTTD5) and this does not fit as they said it should. Has anyone had the same problem? The problem is that the long sliding arms do not match the existing holes....? And the distance between the holes does not math the distance between the holes on the piranha tray.
    I've spoken to the guys at piranha and accoring to them they did send me the correct tray.
    Fitting instructions as per piranha:
    The isolator mounts on the bracket on the tray. Sit tray in position sliding long arm up under insulation behind pipes. These arms line up with existing holes (diesel only) use weld bolts. On the V8 these holes must be drilled. Short bracket bolts into previous horn position. Two m6 holes are drilled for front bracket. Use body washers. Top mount supplied.
    How van I attach a photo??
    Gold Coast, Qld
    Had exactly the same problem a few months back and wasn't willing to drill new holes in the engine bay. Took it back to TJM where I bought it, got a refund and then bought one from ARB - fits perfectly as it should and was a lot cheaper. I beleive the ARB one is slightly bigger as well allowing for a bigger battery.
    Aye, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Greenman Guest
    I recently fitted ARB's tray and had to elongate the holes that marry up to the captive nuts in the firewall and it was still a force fit to the bottom mounting hole on the support. However it's in and looks like it was fitted from new. A good, sturdy product
