Results 1 to 10 of 21
Thread: Firewall alternative for running cable.
    Aug 2015
    Hey all,
    The hole most of us have used to run cable through to the cabin on my D4 has reached it's capacity.
    Is there any other free gromits someone has found? I've poked around but can't find anything.
    Russ
    Feb 2009
    Quote Originally Posted by Russrobe View Post
    Hey all,
    Russ
    I've asked a few times on the forum and never got a positive response. Seems crazy that there's not something behind the glove box.
    Are you able to rationalise your wiring at all?
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Aug 2015
    Quote Originally Posted by Stuart02 View Post
    Hmm not really.
    Next up is a switch for driving lights, can't join that into anything, antenna coaxial cable, traxide wiring, trailer brakes all adds up quick...
    Aug 2015
    Luckily i ran the cb cable through the boot because that wouldn't fit.
    Jan 2015
    Perhaps one of the remote switches mentioned in this thread: Driving Light Switch
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    LRD414's Avatar
    Oct 2014
    I think there is something behind glovebox but it's difficult to reach, requiring battery and fusebox removal or something to that effect and perhaps needing to get behind glovebox fusebox too. I did read of it ages ago. I reckon the remote fob switch would be my go to.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Kallangur, Brisbane
    Drill another hole?
    + 2016 D4 TDV6
    Aug 2015
    Pretty sure you can't go just drilling holes through the firewall lol.
    Mar 2016
    I'm sorry, but why? A 10mm hole is not exactly going to affect the structural integrity? A hole directly next to the existing hole, which has been rust treated and uses a grommet isn't going to harm anything.
    2007 Audi RS4 (B7)
    Williams West Aust
    Another hole should be OK Russ,make sure its where you wont drill into anything.Make it big enough for futher use and make sure you get the correct size grommet.I would paint the exposed steel too.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
