Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: D4 on 35"?
    Jan 2012
    D4 on 35"?
    Hello Together,
    has been a while since I was on here :-).
    Just wondering whether someone on here has a D4 on 35" and what is nowadays available in regards to HD upgrades for a Discovery 4 like CV's, Drive shafts, lower control arms etc......
    Contemplating another discovery build....
    Stefan
    Aug 2010
    Lol Steve! Isn't the new toy enough?
    Not much available for the D3/4 in that regard unfortunately.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    Jan 2012
    Quote Originally Posted by ~Rich~ View Post
    lol need to replace the tourer need more room in the back for kids and an automatic as my knees are buggered... so D4 came to mind.
    still like a reasonable tyre size though, thought by now people may have stretched the envelope a bit with a D4
    Jul 2013
    Lucky8 do some air suspension spacers (2.5") so you can run bigger tyres. Not too sure off the top of my head how much bigger you can go, Im sure if you spend some time on google you might come up with an answer
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Aug 2015
    Gordon mentioned how he went from a D1 or 2 to the D3 and found he had barely anything break on him in comparison during competition.
    275 65 18s or 285 60 18s already push the envelope really unless you want to run off road height full time with rods or llams.
    My 285s rub on the chassis horn a bit. So not sure how you would go bigger.
    Aug 2015
    I adjusted the castor about 5mm or half a degree and that bought it forward enough to stop rubbing...
    Feb 2009
    Isn't the main reason ppl run 35s because they have live axle diff pumpkins to haul around?
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    May 2009
    Quote Originally Posted by Stuart02 View Post
    Good point, would a D4 need 35's with its high lift independent suspension..prob not
    LRD414's Avatar
    Oct 2014
    D4 on 35"?
    I believe the D4 clearance at Off-road height is 240mm and this is relatively uniform across the complete underbody but with the low point where the exhaust spreads to go around the spare. Not sure how that would compare to a live axle diff hung under 35s.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    May 2009
    Yes and no, diff clearance is probably the main benefit in muddy rutted tracks but the greater ability to roll over obstacles the larger footprint and taller sidewalls are also huge benefits.
    Have a look at tuff truck and the like , even if that's not your flavour you won't do it on small tyres. Think of a skateboard mounting a kerb versus a mountain bike , overall diameter is the key
