Results 1 to 6 of 6
Thread: Temp sender differences
    Dec 2010
    Kiewa Valley, VIC
    I have a couple of temp senders in the shed. I think they may be from my old ford resto a few years ago.
    My questions is what is the difference between diff brand temp senders. If they are the same size, same appearance and work with older gauges, will they work in the s2a gauge?
    Im looking at finding a brass adaptor so that I can use one of the temp senders in the shed as a replacement for the 200tdi sender, which won't work with the older gauges.
    Is this a workable plan?
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    Irymple, Victoria, Australia
    I think you will find that they will need to be the correct Ohms to suit the Temperature gauge you are mating them too!
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    JDNSW's Avatar
    You could get lucky, but as a general rule they are all different!
    Dec 2010
    Kiewa Valley, VIC
    whats the usual running temp of the coolant? I could set up a dummy circuit and test the sender with the gauge I suppose.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Dec 2010
    Kiewa Valley, VIC
    The 200tdi runs with a 88deg thermostat, so a LR green top temp sender is required with an adaptor to fit. Seems like I answered my own question - apologies.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    I managed to find a VDO sender that matches the series 3 dash gauge and it reads in the centre (N/normal) of the gauge, when the other temp gauge I have fitted reads between 75-80C.
    I have a couple of packets in the shed, but I think it was this one, VDO 320-002, it's 1/8th NPT thread, so you will need to make up an adaptor.
    Sender Temperature 320.002 vdo
    Below is the VDO sender catalogue.
    Temperature Sensors & Switch | Senders and Sensors | VDO Instruments and Accessories
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
