Results 1 to 10 of 33
Thread: leak inside the car
    leak inside the car
    hi guys
    you ma have seen me recently introducing my self in a different forum, funny only owned the car two weeks and i'm already in the technical forum looking for help and advice as the disco has already started bloody leaking..........i told the boyfriend that is just crying because it has not been offroaded yet.......but to the point we have a 1999 disco which has just sarted leaking fluid into the drivers footwell from behind the dash.
    i can't smell anything so assuming it is water, which leads us to believe it might have something to to with the a/c
    are we right??? has anyone else had this problem if so is it easy to fix ??
    is it easily accessable or do we need to take it to a garage
    thanks for the help
    dullbird
    Somewhat North of Cape York...
    Hi Dullbird,
    welcome to AULRO! Well, Landrovers tend to leak water to the inside and oil to the outside. If not, assume something is wrong. Whilst this can be annoying it is an usual part of their behaviour.
    As I only have owned Disco I models my experience regarding Disco II is not up to the latest standard. To me it seems your problem is related to the aircon. If you can check this and do not find any fault you may find some other sources of the leakage, namely window seals, panel gaps closed with filler (that becomes porous with time), clogged sunroof drains... the list can be extended almost endlessly.
    There exists a "Water Ingress Manual" for most LR models, you might want to check out the emporium if there is one for a Disco II as well.
    Merry Christmas and a Wetty New Year (pardon the pun) to you!
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    Jul 2003
    Merry Christmas Dullbird,
    I don't think that it has rained much in Sydney during the last two weeks? But I bet you've used the AC. So my guess is it's the condensate (water) generated by the AC . There is a tray to catch this under the fancoil in the dash. There is a tube that drains the tray to the underside of the vehicle. This is probably blocked and this is not a rare occurance. :x
    So it's under the car you go and see if you can find the tube either side of the transmission. It would help if you had access to compressed air so that you could blow through the tube to clear it. Then all will be well.
    And then take the poor thing off the bitumen :roll: :wink:
    Mahn England
    Ex 300Tdi Disco:
    Tregeagle, NSW
    My sentiments too,
    when I had the pajero, sadly only gone a month but the houseboss enjoys her new car, so I can't complain i got the disco back.( even though after 15 years of drivng it i still enjoyed the roughness.)
    Back to the problem, as Mahn said a blcked condensation tube will give the internal water leaks, the paj did it all the time, just a case of poking up something thin into the base of the condensor under the dash.
    One other thing a mate of mine just got rid of his disco and bought a D11 because of the same problem. Yours by any chance is not dark green with new alloy wheels and nice new yellow shocks, if it is give me a pm and I'll tell you where the rust holes are.
    john
    Geraldton W.A.
    Merry christmas all ,
    my disco does this & yes it's the condensate drain , it has a bulb type thingy with little fingers on the end which get a bit sticky & doesn't let the water out get under & twiddle with it & 'bout 2 cup fulls of water & crap come out have to do this every coupla weeks, will get new tubes one day
    Toowoomba QLD.
    As said before, its the aircon drain tube caps under the car. Just pull them off the tubes and leave them out. (I have two in my tool box).
    It won't cause an issue unless you go deep water wading. Otherwise you will need to check them reguarly. (Monthly would be about right).
    Trev.
    S.W. Sydney
    mail
    Dullbird you have mail (PM)
    Hi welcome to the Forum
    Is you disco a manual or Auto
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Yass NSW
    My fender did this today on the trip home but on the passenger side. I will be playing with it tomorrow. My drain tube doesn't have anything on the end but it might have been clogged with mud for the trip I did with my brother over christmas.
    SYDNEY -in the shire.....
    <span style="color:blue">i dont remember the discos having drain tubes on the drivers side.......</span>
