Results 1 to 9 of 9
Thread: Cracked Intake Manifold 3.5 81 Classic
    Sydneham Victoria
    I find myself with a cracked intake manifold on my 81 RR. I still run the original twin carbie setup and I think that is all that is holding the carbie support together. It runs from one side to the other and is about 5mm wide at the left hand side and 1mm at the right.
    The crack has been progressive and is growing by the minute. I understand that the chamber has two(2) walls and that only the outer appears to be damaged at this stage and it runs fine with no vacuum leaks. It is not possible to move the manifold at the cracked area.
    I know I have to replace the complete manifold but was wondering if anyone may know how it started in the first place. The engine setup is stock and has never been altered ???????
    St Helena,Melbourne
    4.28 MB
    That is a strange one, is it not leaking coolant ? There is a coolant jacket around the carb casting and into the manifold slightly so it should leak if cracked in that region. I cant see how there would be much stress on the manifold causing a crack, maybe just a casting flaw. I havent noticed an inner wall on any of the manifolds i have modified for a single carb.
    joe Guest
    Loanrangie; You have modified twin carb manifold to take a single 8O ????. HOW? do you mean taking off the old one and putting on a after market single one or do you mean you are actually cutting the old one somehow to fit a single. If the latter HOW???.
    We would love to know as it would save$$$$$ on buying the over priced stuff Edellbrock sells .
    Thanxs mate from Joe.
    St Helena,Melbourne
    4.28 MB
    Only got back last night after 6 days away, you just cut the triangle casting off the manifold with a grinder and then get it milled flat, buy a 2brl holley to stromberg holden adapter and bolt it to the manifold after drilling and tapping holes to suit. You could also use a stromberg off a 253 if you arent keen on the holley, i have just swapped the holley and manifold from one rr to another with lpg setup and its great, good power and better economy.
    Email me and i can email pics. I also have a 4brl holley to stromberg adapter and a 450 holley that i am going to fit.
    Regards,
    Nick.
    Sydneham Victoria
    Gave up on the cracked manifold theme.
    Got myself an EFI inlet manifold, blocked every hole I could find, removed the throttle body, bolted in a supercharger and pressurised the system with some excellent results so far with a Holley 350 carb and 4psi boost.
    Will carry out some durability tests and report back. All fabrication performed by my bro.
    RaZzA Guest
    Wow - thats cool keep us updated!! 8)
    St Helena,Melbourne
    4.28 MB
    So its setup as a draw thru system with carb before the blower ?
    Sydneham Victoria
    That's correct.
    I have some pictures but I am not sure how to post them.
    My RR had the setup with the alternator on the drivers side, I relocated this to the top where the air pump used to sit. The carb sits on the blower (blower donated from a toyota crown) and the forced induction is fed into the EFI manifold which now has an air fuel mix rather than air. The blower and carb are now located where the alternator once was.
    So far it has been a pig to start but once it is up and running idiles quite well. As you can imagine I am running a little hotter than usual too, I am working on this along with a modified, or rather, custom made air hat and filter system. I only have 35mm between the top of the carb and the bonnet.
    The blower also creates a vacuum sorce which now draws from the rocker covers. The particular blower is not very efficient and does not have any teflon seals or similar so the vacuum from the rocker covers also supplies some oily lubrication. This also stops blow by which can be produced by forced induction.
    When I figure out the picture thing I will post them....
    In general the low down power/torque is instant, 4psi is just amazing.[/img]
    St Helena,Melbourne
    4.28 MB
    Upload the images to the gallery then link them to your post.
