Results 1 to 10 of 16
Thread: tyre pressure
    tyre pressure
    hi
    can someone give me an idea of what sort of pressures we should be running the disco on here in this heat as we are not sure the disco is on 16's i think and is running a/t
    we have been running he 90 on 35 in the uk but not sure here with the heat and stuff
    thank you
    dullbird
    Jul 2003
    Hi again,
    Tyre pressures and the Meaning of Life eh :wink:
    There is the 4 PSI rule that says that the tyre pressures are right if after say 20 minutes of highway speed driving the pressure of the tyre when measured warm is 4 PSI higher than the pressure when measured cold....hmmmmm...far too scientific for me (I'm into Intelligent Design Not).
    35 PSI is a good start and then experiment as it depends on the load and the road temperature and the speed and the roughness of the road and the ambient temperature etc etc
    Start with the placarded recommendations.
    Don't to be too precious about pressures for day to day driving except if they are below 30 PSI and above 40 PSI on road.
    You're on the right road though.
    Mahn England
    Ex 300Tdi Disco:
    SYDNEY -in the shire.....
    <span style="color:blue">lurch runs 40psi front and rear when i remember to check them........
    your recommended tyre pressures should be 28 front and 38 rear.......
    most of us reckon that 28 in the front is way too soft for on road......</span>
    Yass NSW
    In the ford we run 32psi and in the fenda I run between 40 and 50 psi. Good on the fuel but might be a hard ride but then muds on a defender aint designed for the ultimate ride comfort anyway 8)
    I up it to 50 for long trips and just check them every now and then normally and up them to at least 40 if they are low.
    Feb 2005
    i run
    hi way 40
    long drves onthe dirt 30
    sand 20
    Williams West Aust
    Hi Dullbird
    Chasing fuel economy I put my Disco2 tyres(Cooper Discoverer ST 255/70x16) up to 34 front and 36 rear.I have just dropped them back to 32 front 34 rear as it was too harsh with our POO QUALITY ROADS(I work on roads for a living and there is a huge room for improvement,roadtrains are destroying our roads)
    I was running30/32 and will drop back to that if the ride is still too hard.
    My Disco has done 205000Ks so it probably needing a set of new shocks.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Toowoomba QLD.
    I like simple numbers, so I run the fender 300kpa rear (280 placard), and 200 kpa front (190 placard).
    In english that translates to 29psi and 43.5 psi.
    Tyres are 235/85/16 Grabbers, (standard rubber off the showroom floor).
    Trev.
    South Yundreup,WA.
    I generally run 38-40psi front and 40-42 psi rear. I find too low in the front makes the steering less responsive and causes premature wear. Sometimes there is a big difference in what the car manufacturer and the tyre manufacturer recommend. Most 4x4 tyres I have used recommend 35-40psi and some up to 50psi. On normal sedan tyres it is lower and I normally runn these at 32-35psi.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Gold Coast, Qld
    I have 265/75/16 Muds on my D2 with fairly firm suspension and I normally run the following.
    Road (day to day) - 30psi all round
    Longer road trip - 35psi all round if empty, 35fr 40r if loaded
    Short gravel road sections - 28 all round
    Off road, rocks, low range stuff - 22psi
    I have just gone by feel really but have found these to be adequate. Speed is really the dictating factor when dropping pressures.
    Good luck
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    NSW far north coast
    wow, I'm running much lower pressures in the 'fender with BFG MT 255/85's than the majority.
    Generally 1/2 tonne+ in the back, fully loaded with bar work, winches, etc. 30-32 psi in the front 30-34 psi in the back, 26 psi on pure gravel.
    A little bit sloppy in turn in response, (I put this down to tread squirm on a full tread depth muddy. This can really be felt when going from less than 3mm tread depth to new 14mm tread ) but best overal tyre wear/grip for this combination in the 130. Just replaced them and was at 57,000km, and almost down to the tread wear indicators with even wear. I travel a mixture of gravel/broken rough bitumen/highway everyday, and am known to push on a bit in corners (momentum is my friend )
    FWIW, we run 34psi front, 30-32 psi rear (empty) (36-38 towing) in the Patrol ute with BFG AT 265/75/16's. Running similar pressures in Cooper ST's went 80,000km with relatively even wear.
