Do you have any way of reading fault codes?
My Discovery 3 has a transmission problem. The car has done 120 000 kms and has had a transmission service done at 100 000 kms. at that time I had the pan conversion done as well.
My problem is that I have a 2 tonne caravan and the car won't tow it. After a short distance towing, say up to 100kms, a big F shows up in the transmission window, the car loses power, and then settles into a lower gear that limits me to 80kms/hr @3000 rpm. This makes for a very slow trip. During these episodes the car does not change up or down. I am locked out of manual and sport modes.
I drove to Queensland like this. Unhooked the caravan and everything went back to normal, until I had to move on. Then the first hill killed it again. I left the van in storage and drove back to Melbourne without incident. I have since done another 15000kms and no problems have shown up.
This is my second D3. I love the cars, my family reckon I'm an idiot for staying with the brand. My first caught fire and burnt to the ground.
Any suggestions???
Shane
2005 D3 TDV6 loaded to the brim with 4 kids!
http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberWhich oil was used in the trans service , and is yours possibly an 08 / 09 model?
Genuine ZF oil was used in the transmission and yes the car is a 2008 model
Just thinking are you able to monitor the trans oil temp while towing? Could be getting too hot while your towing and causing the fault?
Shane
 Master
						Master
						Perhaps putting the vehicle on a dyno & loading it up would replicate it?
 Master
						Subscriber
						Master
						SubscriberBefore I became educated about the "Filled for Life" furphy and also towing a three ton van, on hot days going up hill sometimes I would get transmission "F" etc where I would limp to a pull off then idle engine for approx ten minutes and clear the faults then continue on as per normal, since then I had changed the oil twice them 60k ago replaced the gearbox, and now I have all the gauges to warn me about whats going on with the car
I have an "Engine Watchdog" gauge on my dash which tells me the transmission oil temp plus radiator coolant temp of the fluid entering the motor, I have a Scangauge to tell me what the internal engine temp is plus this gauge gives me volts, MAP (Manifold Air Pressure) which I use to monitor economical touring and digital RPM which indicates if there is more than normal rpm fluctuation for the same speed/load.
This is the link to a previous post that shows the setup of my dash.
D3 extra gauges on the dash
Ryall
