Results 1 to 9 of 9
Thread: Headlight replacement problem
    Nov 2016
    Sunny Coast
    My left headlight stopped working yesterday so i bought a new bulb and proceeded to replace it. Well, it also didn't work. So, I checked to see if power was getting to the bulb and it isn't. The fuses seem to be intact and the right hand light works. What do you suggest is the next thing I should check?
    Nov 2013
    first check your connector doesnt look like mine did!
    there is another 3 wire connector that you should also check, on the far right of this diagram.
    then try tracing the wires back as far as you can looking for any damage. is it shorting somewhere?
    Nov 2013
    my last post assumes you have a perentie.
    if all else fails, do yourself a favour and buy a traxide headlight harness.
    Nov 2016
    Sunny Coast
    Thanks. That is probably the answer. Yes, I have an '88 Perentie. The H4 connector looks okay. I checked the earth connection and things got really weird. The middle slot on the H4 connector is connected to a black wire which would be ground, correct? The black ground wire one doesn't earth which I'm not surprised since the middle socket should be for low beams. One of the two outer wires (blue white) does ground. So, it may be best to just replace the harness as you have suggested. The trade includes the relays, correct?
    Nov 2013
    Yep black should be earth. But if the power isnt getting to the connector then I'd guess the problem is further back.
    Worth also checking the switch. I can't recall if both left and right feeds go all the way back to the switch or whether they split further down, if that makes sense.
    the traxide kit has relays. Get the kit with the parts for adding driving lights, makes that task much easier also. Even if you figure out this problem you'll probably have something else go later anyway so the kit makes good sense.
    good luck
    Nov 2013
    Thinking again, the L and R are only separate back to the fuses, so I'd say your problem is between the fuses and the light.
    Hay Point
    Quote Originally Posted by The Beast View Post
    Don't forget that left and right headlights and parkers have separate fuses and circuits. Best advice is to fit HD relays to both L and R lights.
    Cheers......Brian
    1985 110 V8 County
    Nov 2013
    Quote Originally Posted by Bearman View Post
    Agreed. Upgrade the whole lot!
    Nov 2016
    Sunny Coast
    All upgraded now and found the fault well, faults actually. Seems the left light was incorrectly wired. Why it work at all is beyond me but that was now been fixed. Second is a few fuses were a bit dodgy and third and probably the reason it failed finally was the ground connection for the left hand light was dodgy. So all done, upgraded and working. Thanks for the help.
