Thread: Shocks and front turret.
    Feb 2016
    Looking at getting ome shocks put in front and rear. Open 617mm closed 359mm. Front and rear.
    Being told they wont space the front turret or put a taller turret in but will put extended bumpstops. Is this ok? Do I need taller turrets?
    i believe they are a 105/80 series ome front shock
    NSW far north coast
    Longer bump stops will stop the shocks going metal to metal in bump, but will restrict ultimate bump travel.
    In my experience you need to lift the turret 1/2" or so, and then you get a more balanced bump/droop ratio.
    Droop or down travel is restricted by the inherent roll stiffness of the bushes in the radius arms anyway.
    To increase droop you either need
    a) holey bushes
    b) disconnect on one radius arm
    c) 3 link
    d) Superior radius arms
    Also bear in mind that your front driveshaft will probably bind the uni at full droop unless you have a wide angle yoke or a DC front shaft and if you are running a front anti-roll bar the driveshaft will crash into it at full droop.
    Change one thing from stock and you create a whole lot of other compromises.
    Feb 2016
    Quote Originally Posted by rick130 View Post
    a) holey bushes
    c) 3 link
    yeah it will work just that the upward travel won't tuck as much. That is what I thought. I don't think il get that much droop that I need to worry about the drive shaft. I'm also planning to try the 90 without the front sway bar.
    I want ant to try stay away from changing the shafts.
    NSW far north coast
    Quote Originally Posted by D90 orkney View Post
    yeah it will work just that the upward travel won't tuck as much. That is what I thought. I don't think il get that much droop that I need to worry about the drive shaft. I'm also planning to try the 90 without the front sway bar. I want ant to try stay away from changing the shafts.
    If you're running a front anti-roll bar and won't be replacing the front shaft stick with stock length dampers. Although I think the TD5's used a wide angle yoke on the front shaft anyway ? I know a Tdi will bind, been there, bought the Tom Woods DC shaft, and I had ditched the front anti-roll bar too. Ran holey bushes for twelve months, they work well at increasing articulation but the compromise is they tend to have a short life and when at the end of their life the on road manners are interesting. I doubt if there are any around anymore either. One point to consider, OE Defender radius arm bushes are twin shell, Disco and RRC are triple shell, one outer, one inner and one in the middle. These are a stiffer bush, they sort of act as an anti-roll bar. Use Defnder ones if you are after increased articulation, or surprisingly Super Pro bushes flex pretty well while still giving good on road manners. [edit] Forgot to ask, TD5 or Tdci ? Tdci will have issues with long travel dampers due to the increased angle of the driveline
    Feb 2016
    Its a puma 2.2
    im being told with these length of shocks I womt
    need to change the shafts.
