Results 1 to 10 of 15
Thread: Hi flow diesel adaptor
    Tuross Head NSW
    About to travel again towing 21 foot van and find the newer servos not van friendly so forced to use the truckies lanes but seem to be all hi flow pumps and the larger nozzle. Tried all the searches, is there an adaptor in Oz on the market? or am I left to cutting up a funnel ?
    2016 SDV6 SE Graphite "Pearl"
    2003 td5-Auto--- sold
    1992-200tdi Man---gone.
    Quote Originally Posted by Kandy View Post
    Not necessary, don't be in a rush, just open the trigger slowly to get a flow rate that the filler neck can handle
    Mar 2016
    As Nicky said, the nozzle fits, you just use about half trigger to meet the cars flow capacity
    2007 Audi RS4 (B7)
    Tuross Head NSW
    Thanks for above . Will try again before departure. VW makes an adaptor for the hi flow nozzle overseas. Might enquire locally.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    The filler neck is wide enough to take hi flow nozzles on a D2.
    I actually increased the size of my breather after having some nightmare foaming issues especially out in the hot areas of the country where the fuel gets quite warm.
    I am led to believe that the new diesel fuel coming into Australia now has anti-foaming properties.
    Just squeeze the lever judiciously.
    99.87 MB
    Quote Originally Posted by ramblingboy42 View Post
    On a side note, how did you do this? Did it solve the problem? I usually fill up using hiflow because of the 150l tank.
    Slunnie
    Feb 2010
    I use the high flow pumps in my D3 all the time. With the long range tank it takes upwards of 10-15 minutes to fill up on a normal bowser. I have no problems but do ensure it is fully in and do also start and finnish slow.
    Feb 2009
    On a D4 or just a D3?
    Quote Originally Posted by DiscoJeffster View Post
    DiscoJeffster, is that on a D4 or just on a D3? I briefly had a MY09 D3 and from memory I think the hi-flow would fit but not on my MY12 D4 (although I tried only once).
    Mar 2016
    Mines a D4 and I've used a high flow. It doesn't go all the way in, but far enough to fill.
    2007 Audi RS4 (B7)
    Nov 2015
    Black Rock
    Slightly OT, but on a D4 3.0 can you use a filtering funnel without triggering the misfuelling device? If so, can anyone recommend a suitable funnel?
    2013 D4 expedition equipped
    1966 Army workshop trailer
