Brake pad sensor come adrift ???
Martin
Just noticed it hanging down on the front passenger wheel.
I also have the 'check brake pads' warning on the dash which appeared after travelling on a rough road for a few minutes. It flickers on and off occasionally while driving, and my pads all seem fine.
Martin
Yes it's the brake pad wear sensor
2007 Audi RS4 (B7)
Goes here ....
Photo is of rear.
Link to my D4 Build Thread
D3 2005 V8 Petrol
The brake pad wear sensor appears to be broken, or almost broken and the circuit is opening and then connecting giving intermittent fault.
Temproy fix is too cut wires and join together to make a NC circuit. Need t fit a new wear pad.
Ivan
2005 D3, 245/70/17 STmax, Tvan, Traxide, Mitch hitch
If you plug it back in and still get the warning on the dash you'll need a new one. Pretty cheap genuine or even cheaper on eBay.
Thanks everyone! The sensor is broken and beyond repair so i have ordered a new one, bridged the picture in the meantime.
