Results 1 to 10 of 12
Thread: LAZER spots from Prospeed-UK
    Sep 2016
    New South Wales
    Just ordered these bad boys with wiring harness and spot mounts.
    Ben was great to deal with LAZER spots from Prospeed-UK
    Now the wait...
    LRD414's Avatar
    Oct 2014
    Wiring harness allow for piggy back connection to factory or just comes with a plug and tail?
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Sep 2016
    New South Wales
    Quote Originally Posted by LRD414 View Post
    Three methods Scott.
    1. 8225-12V-SP wiring kit (8225-12V-SP), which enables you to wire the lamps just in the engine bay, without the need to pass wires through the bulkhead. It means that the lights will always switch on when you turn your vehicle high beams on.
    2. If you want a separate switch in the dash, then you can buy the 8225-12V-SW harness kit (8225-12V-SW).
    3. If your Discovery has Bi-Xenon headlights, and you want the lamps to activate directly with the main beams (i.e. without a separate switch), then you would need to buy the CanM8 module: CANM8 Cannect Highbeam - Electrical & Wiring - Products.
    Andrew
    Sep 2016
    New South Wales
    Quote Originally Posted by Crofty View Post
    Andrew
    I'll chuck some pictures up once they are fitted.
    May be a while until that happens, my baby has just gone in for $18k's worth of hail damage LAZER spots from Prospeed-UK
    Only method 2 is legal in AU
    Sep 2016
    New South Wales
    Yep made sure I got the right one LAZER spots from Prospeed-UK
    Sep 2016
    New South Wales
    Finally got round to fitting the LAZER spots so a couple photo's for you all to see. Very impressed with the fitment and the power of these lights!
    Mar 2017
    Armidale, NSW
    Crofts, any chance of a picture of the mounts please?
    Laurie
    All the best,
    Laurie
    2019 sd6 SE
    2012 SDV6 SE (Son stole it from me)
    Sep 2016
    New South Wales
    Quote Originally Posted by Strop View Post
    Laurie
    Hi mate,
    Unfortunately I never took any photos whilst adding the mounts.
    Here are a few more photos showing the mounts and the different configurations of spots available.
    Andrew
    Nov 2015
    Black Rock
    Yes, but Option 3 (CANM8) caters for that: "There are 2 connections to the vehicle CAN Bus wiring (CAN Hi & CAN Lo) along with a connection to a switched 12v power supply and an earth connection."
    2013 D4 expedition equipped
    1966 Army workshop trailer
