Thread: Oil change perentie 6x6/spill
    Shootozzie Guest
    Just changed oil in my landrover perentie 1996 but to my dismay At least 3 ltrs ended up spilling out of A hose attached to a reservoir near the oil filters,is this an overfill safety?or did I fill engine to quick?
    does any one know
    in the wild New England, NSW
    Quote Originally Posted by Shootozzie View Post
    .... A hose attached to a reservoir near the oil filters ...
    I'm thinking that a quick snapshot or three from your phone may help us understand what you are referring to.
    No safety overfill devices that I am aware of -
    1. What does your engine dipstick indicate ?
    2. Where did you fill - the rubber stopper in the rocker cover is the correct spot :-)
    Bearman's Avatar
    Hay Point
    does any one know
    That would be the breather hose from the rocker cover. You must have had the rocker cover full for it to go into the breather - sounds like you definitely have filled it too quick! How did you fill it - with a power hose setup?
    Cheers......Brian
    1985 110 V8 County
    Shootozzie Guest
    No filled it with a funnel only,wasn't fast at all but funnel sealed the oil hole well
    Shootozzie Guest
    Motor still needs an oil top up!
