Results 1 to 6 of 6
Thread: RRC Hubs
    Nov 2008
    RRC Hubs
    Recently picked up some nice Disco 1 Freestyle Alloys, to fit to my 81 2 Door. Went to fit, fronts went on no problems but when I went to fit the rears they would not fit over hubs? Tried swapping wheels around no difference. Measured across centre and found rear hubs to be about 1-2mm wider?? Stopping wheels from sitting flush on the hub. Had to grind down inside of wheels a little till they slipped on. Have had car for 28 years and don't remember ever changing hubs. Any ideas on why they could be different.
    Joe
    May 2006
    Woolgoolga
    It will be the drive flanges
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Vern View Post
    Yep , had to grind my rrc flanges a little to fit d1 steel rims.
    Its more the inconsistent casting than anything else.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Nov 2008
    Thanks will revisit to see if it was flanges after all.Even though wheels were sticking as they got closer to flat where they seat on hub.
    Nov 2008
    You guys were right it was the flanges, ground them down a little~ level with hub, and wheels slip off and on easily, wasn't 100% happy with previous solution. Keep going back into shed to look at it, looks a treat!
    Thanks again Joe
    May 2008
    Bundaberg Qld
    Quote Originally Posted by trumpycam View Post
    Thanks again Joe
