Thread: Has anyone seen one of these in the back of a Disco 3?
    Dec 2011
    Adelaide
    142.79 MB
    Spotted this mesh holder today in the back of a wreck and was wondering if anyone knows where it might come from? Land Rover??
    Any idea on a part number???
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    LRD414's Avatar
    Oct 2014
    It is a factory option for that side trim. Don't know part number.
    I think it may have been for certain lower spec models, perhaps even the 5-seater but that's a guess.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Wantirna South, Vic
    AFAIK it's only useable if you don't have rear air. That's a grille for ventilation if rear air is fitted.
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    Oct 2013
    Old Toongabbie, Sydney NSW
    I've got rear air and that spot's covered by a grille so you are probably right. The rear air fan is located on that side in the access port behind this spot. I have a similar recess on the other side too but the shape is reversed and larger. I believe that I've seen a previous post with a net over the RHS one.
    Martin
    Quote Originally Posted by winaje View Post
    Dec 2011
    Adelaide
    142.79 MB
    Quote Originally Posted by letherm View Post
    Martin
    Thank you.
    This will sound stupid, but now I know I have rear air!!!!!!
    Yes, I've got the grill on the pass side and the recess on the driver side.
    Strangely enough, coming back from Sydney, I "discovered" the tow bar attachment in the rear compartment (that was after giving the selling dealer some stick about it missing!).
    When I found the towbar, I did wonder what the contraption was next to it, and now I know.
    Doubt it will ever get used, but who knows.
    REMLR 012
    Oct 2013
    Hi
    You should also have a control panel for rear air on the roof behind the front row seats. Also you can control whether the rear air is on from the drivers seat. There is a button around sort of part of the air con dial at about 7 o'clock that you can select rear air off, same as front or rear passenger select.
    Martin
    Quote Originally Posted by Aussie Jeepster View Post
    Thank you.
    Dec 2011
    Adelaide
    142.79 MB
    I think this is quite funny as I made sure I had the air con switched on all the way from Sydney to Adelaide...............the rear air con!!!!!!!!!!!!!!!
    Yeah, I know RTFM!!!
    It will never go on again.
    REMLR 012
