Results 1 to 10 of 15
Thread: Instantaneous oil level in a D4
    Jan 2009
    Around the time of the forum meltdown, a very knowledgeable forum member posted a method of measuring the oil level without having to wait for the D4 to sit and think for 10 minutes. I have searched for the post, but it may have disappeared in the meltdown. Can someone help please?
    Andrew
    D4 MY16 SDV6 HSE e-diff, IID, LLAMS, ARB Summit bar & Intensities & twin compressor, Traxide, GOE sliders & guards,
    TowPro Elite, Mitch Hitch, Rhino platform, Drifta drawers, GME UHF, ProSpeed rear ladder
    Oct 2016
    Perth, AU
    According to the workshop manual, navigate to the 'Not Available' oil level screen, then press the cruise control cancel button twice within two seconds.
    The 'normal display' should now be up.
    Press the OK and follow the instruction
    Haven't tried it myself though...
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Jan 2010
    the bonnet must be up is also a requirement I found. No good if you have bypassed the switch to fix your alarm.
    Jan 2015
    I think this is the thread you are looking for: Checking oil level
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Mar 2016
    The bonnet probably explains why this has never been successful for me
    2007 Audi RS4 (B7)
    Jan 2015
    Quote Originally Posted by DiscoJeffster View Post
    It's worked for me and I've never opened my bonnet to do it.
    I haven't tried the cruise control button either, just waited 5-10 minutes...
    David
    Mar 2016
    Quote Originally Posted by l00kin4 View Post
    David
    Yes. Waiting works, but the immediate method has never. I think bonnet open might be the secret I'd been missing.
    2007 Audi RS4 (B7)
    Jan 2015
    May be the same for me - I will give that a try too.
    David
    Jan 2015
    Quote Originally Posted by disco4now View Post
    I had a look at the workshop manuals for MY09-12 and MY14 - cruise control button is mentioned but nothing about bonnet being open...
    David
    Jan 2010
    Bonnet needs to be open.
    Looks like my original tip about the bonnet needing to be open did not survive on the original thread. I was wondering why there was no love or at least being told I was wrong.
    I checked it twice at the time, but I now have my bonnet switch bypassed so can't check easily again.
    This is the sort of thing that can't wait till tomorrow, its not that cold, someone should go out to the shed and start the engine and then check it!
    Gerry
