Results 1 to 9 of 9
Thread: Defender audio
    Scarborough, QLD
    Defender audio
    So, SWMBO insists that I get better audio in the Defender. I've currently got average speakers in the stock standard location near the front passengers knees. These are attached to a Kenwood DDX-5015DAB.
    My old poptop troopy had speakers above the driver in the ceiling, which worked really well. I'm thinking about doing this in the Defender (I've removed the original roof lining) by attaching them to a thin sheet of aluminium. If so, I was thinking of swapping the current speakers for bass type jobs, and adding the top speakers for treble (not sure if this is the correct terminology).
    I also need speakers in the roof at the back for the kids - what speakers should I look for?
    Finally, do I need an amp, and if so, what's a decent entry level unit?
    Oct 2007
    Wantabadgery, N.S.W.
    I put 6" speakers in the headlining above the front seats and 6x9" in the back above the back window. I have an ordinary sony head unit, no amp, and the sound is as good as you'd want it I reckon. If you've got no headlining, glue some shaped timber blocks to the inside of the roof with roof and gutter silicon. Clean the area with metho first.
    Don
    In my opinion, if you want to improve the audio in a Defender the first thing to do is improve the acoustics in the cabin. This can be done with the addition of some dampening, such as Dynamat, to reduce the resonances in the panels, as well as some soft surfaces such as carpet or foam to reduce the reverberation in the cabin. Then you'll actually be able to hear any improvements you make to the stereo components.
    Although it's a Puma, there's a few things in my build thread which may give you some ideas.
    Jon
    Bracken Ridge, Qld
    Does anyone know of a set of splits - with 4" main speakers (for standard location) and separate tweeters (for on the dash). ?
    I've been looking everywhere with no luck so far.
    Seems that if it isn't standard size for a Bombadore or rice racer, nobody sells 'em.
    edit: I did find these:
    NEW VIBE SLICK4C-V3 SLICK SERIES 210 WATT 4" COMPONENT SPEAKERS SPLITS EURO FIT | eBay
    but no idea if they would be any good. Thoughts ?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Apr 2015
    Bondi Junction
    Strathfield car radios have a set on their website - alpine ste-g100s type e
    I fitted Focals:
    Alasdair, the MY16 Keswick 110
    I bought them from Alberts in Perth.
    Jon
    Kingston, Tassie, OZ.
    Speak up!! I'm finding it hard to hear you...
    Its a Defender for goodness sake! Try listening to the glorious sounds of a tdi/td5/tdci and the frenetic transfer case whine instead.
    Jc 😎
    Scarborough, QLD
    Jc 😎
    Tell that to the missus! 😁
    You could try Alex Minassian in Slacks Creek:
    Alex Minassian - Land Rover Car Audio Installations
    For speakers I've got Polk's in a 4" speaker in the disco/rangie.
    84 Alfetta GTV
