Results 1 to 10 of 34
Thread: T/C leak,has anyone got a guaranteed fix.
    Safety Bay
    So I've had enough of gearbox to T/C seal leaks,has anyone got a fix they used that's guaranteed to last longer than 12 months?.I'm seriously contemplating putting a gasket between the GB and TC or a tube of ultra blue.So what techniques have members used that worked. Pat
    Jan 2014
    Perth Western Australia
    Is it leaking gearbox fluid or transfer case fluid?
    Either way, are you replacing the the sleeve that both seals run on?
    Its cheap and not difficult to replace.
    Daz
    Daz
    Safety Bay
    Daz,the Tdi has been leaking for 15 years and the TDCi started about a month ago,I have a feeling both are leaking from the intermediate shaft or T/C input seal.I don't want to remove the T/C's because they are an awkward PITA on your own in the driveway so I'm thinking of sliding them back on longer bolts and a trolley jack enough to either get a good bead of sealant in between or a gasket.The best fix is a sleeved casing but that's not going to happen at the moment. Pat
    Oct 2007
    Wantabadgery, N.S.W.
    I'm also interested in this issue. I got the T/C re-sealed and a 'new' reconditioned R380 fitted 18 months ago. Already something is leaking. On my list today is to find out which one.
    Then comes the job of pulling stuff out and fixing it, so I don't want to do it again for a long time.
    Don.
    Jan 2014
    Quote Originally Posted by PAT303 View Post
    Awkward you say??? .....and.... its a Defender.
    Your talking about the standard transfer case leak, good grief dont bodge it up with goo, sheesh..
    The old Defender is prolly due for a rebuild by now anyway?
    And the "new" Defender has done what 100 - 150K? so hrmm same same
    For goodness sake, just pay me the big dollars and send both to me to fix
    Daz
    Daz
    alien's Avatar
    alien is offline A Keeper of the TGO Silver Subscriber
    Bacchus Marsh Vic.
    From what I've read and experienced the leaks is usually the intermediate shaft O rings.
    There is a modification where the housing is machined and a sleave inserted the stop the leak.
    Ashcroft Transmissions
    There are members on here who have done this modification locally too.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Safety Bay
    Quote Originally Posted by DazzaTD5 View Post
    Daz
    Rebuild Pffff,she's only done 507K,just bedded in.All the improvements such as sleeved housings etc only work for a year or two before they start again,the reason I'm thinking of sealing the two halves together.A few hours work with a good flexible joint sealer is worth the effort if successful.And yes the T/C is awkward for one person lying on their back in their driveway,we don't all have a hoist in the back shed . Pat
    Jan 2014
    No no no... that wont work! because the intermediate shaft is just about clear of the gearbox adapter housing so sealing between the two wont work.
    And if you mean sealing between the two as in from left to right, in between the two housings...... then well thats just a disgusting thing to do to a Defender..... and it still wont fix the leak
    If you persist in complaining about ur leaking Land Rovers, do this...
    Remove transfer case.
    *undo retaining nut on intermediate shaft and tap back a wee way and remove o-ring.
    *clean end of shaft and as much of the transfer case face around the shaft as you can with brake clean and a brush.
    *replace oring, and then use your sealant (I use Dow Corning 732 white on transfer cases) apply sealant around shaft (yes round the o-ring, all very incorrect).
    *refit, apply sealant over the end of the shaft, you will see that the shaft once fitted back will sit a few mm below the case face, fill this with sealant and use a flat tool/scraper as like a putty knife and trowel it flat.
    If you have been squeaky clean this will work.
    Daz
    Daz
    Safety Bay
    I've done the O rings and seals in both vehicles,as have many owners,what your saying is similar to what I was looking at doing.It's just annoying that the intermediate shaft is covered by the gearbox housing,another half inch more clearance you could do the o ring without removing the T/C.
    Sep 2010
    The Hills.
    152.79 MB
    Run them without oil. That way they can't leak, and Dazza can get some work... God this stuff's easy..
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
