Results 1 to 10 of 24
Thread: Large rainwater tanks from Tamworth to Barossa..
    Dec 2009
    Williamstown, Barossa, SA
    Hi all... Sooooo, I'm stuck between a rock and a hard place... As some of you know, I have recently finished/moved into a new house.. The original plan was to site two 22500lt Polymaster rainwater tanks in under the rear carport so they're within the fire safe (sprinkler) zone. This was to happen before the roof went on as they're 2500mm + tall. However, as the build has been far from fluid, this was one of the things didn't happen. Luckily, those tanks have been pressed into action else where. So... I now need two 'low profile' 22500lt tanks. The only company I've found who do these is RapidPlas who are based in Tamworth NSW. The low profile tanks they offer are 3840mm wide, and 2220mm tall. They fit the bill and are priced similar to all the other 22500lt tanks on the market.
    Here's the problem.. They don't supply South Australia, and want $2500 to get them here... Sooo, I'm contemplating making a lightweight low chassis single axle trailer and collecting them from the edge of their 'free delivery' zone, which I believe to be Hay.. but before I go off on a mad dash making a trailer, and then doing two return runs to Hay (hoping to find somewhere to get them dropped off there short term..), I thought I'd ask the great powers of AULRO...
    Any ideas guys and gals?
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Yass NSW
    Make a wooden frame to support the tanks on a car trailer and use that? Cheaper than building a trailer.
    Regards,
    Tote
    Back down the hill.
    $2500 is a bargain, grab it. You won't build and rego a trailer, then drive 7,000 km (over 3,000 with an accredited pilot) for less.
    http://www.rms.nsw.gov.au/documents/...conditions.pdf
    Crafers West South Australia
    Your load can be 2500 wide and 5300 high. Is your truck bed under 1450 high? That and a car trailer with a wooden frame and you'd be OK.
    Sep 2010
    The Hills.
    152.79 MB
    5.3? Wish I'd known that when I was pulling 4.6 trailers and arguing with the RMS. Although, to be fair, most of the arguments were about cubic weight, whatever that is. However, I do believe that a permit would be required to go above 4.6, at least in NSW. SA beats to it's own drum of course.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Back down the hill.
    4.3 high, permit to 5.0, escort and permit above.
    Sep 2010
    The Hills.
    152.79 MB
    What he said. Well, not quite. Had no issues with 4.6, unless I was in Sydney, of course.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2008
    Bundaberg Qld
    What about digging the taller tanks into the ground to get them under the roof line.
    I won't argue with that, over 5.3 is what sets off the SE freeway height alarms.
    Sitec,
    Is diameter a limit in your install or just height?
