Results 1 to 10 of 17
Thread: Disco Td5 new fuel pump
    Jun 2017
    Chisholm NSW
    Hi guys
    I need some help here please. The fuel pump on my 2003 Disco Td5 has expired so I need to organise a replacement. (There is no whirring sound at all when I turn on the ignition)
    Is the actual pump a replacement item or do I have to buy a complete assembly? There seems to be a a large price difference in online prices so I'm wondering if I'm comparing apples with apples, i.e. actual pump or full assembly.
    Is there a preference for any particular brand? Any help would be greatly appreciated.
    Melrose SA
    Quote Originally Posted by oztayls View Post
    Hi guys
    Check the relay that controls it maybe the connections are corroded or the relay has died
    Much cheaper if it is the case also better than replacing the pump to discover it still doesnt work
    Jul 2014
    west of Transylvania
    +1 for the above, first of all make sure it gets feed, if you'll need a pump the best is VDO but it's expensive, cheaper aftermarkets are lottery but can be even a winner depends on luck
    Jun 2017
    Chisholm NSW
    Thanks guys, makes sense. Will check!
    Avoca Beach
    AFAIK it is best to buy the full assembly and VDO is the preferred brand. I was lucky to get one on special from LR Direct in UK.
    I have seen it reported on here that it is also best to get a new gasket. The pump is held in by a big plastic "nut" for which there is a special tool but you can get away with a big screwdriver and hammer if very careful.
    You probably know that there is a porthole in the boot floor for access. I found it best/easiest to cut the carpet with a box cutter under the side bins rather than remove everything. You can then roll up the carpet from the back after removing the trim strip.
    The hoses are removed by pressing in the buttons and pushing forward then back. I found it best to bend the arms of an offset pair of small needle nosed pliers to push in the buttons.
    Regards Philip A
    Jun 2013
    Augusta WA
    Jun 2017
    Chisholm NSW
    You've all been most helpful, thank you.
    By the way, does anyone here have the specs for the fuel pump itself, ie. pressure and lpm? It could help to cure reliability issues to know what the equivalent Walbro pump is. Not to mention the massive cost saving it would be to just swap out the pump for what is a more reliable unit.
    Jun 2017
    Chisholm NSW
    Relays and fuses all checked out so conclude that the pump has died. Have ordered a VDO from LR Direct. They were by far the cheapest, even allowing for shipping from the U.K.
    Avoca Beach
    It is not so simple Grasshopper.
    The pump is actually 2 pumps , a low pressure pump which feeds into the filter which then feeds back into the high pressure pump which then goes to the engine.
    I don't think you will fin a Walbro equivalent.
    Regards Philip A
    Jun 2017
    Chisholm NSW
    That's nuts
