Results 1 to 10 of 37
Thread: Optima yellow top as starter battery??
    Ean Austral Guest
    Has anyone used 1 of these as a starter battery ? I think I recall see someone fitted 1 but think they had to make up some new leads as the terminals were the wrong way around.
    Thanks and Cheers Ean
    DiscoMick Guest
    Aren't they a bit small to be a starter? More of a deep cycle. A diesel needs a large battery to kick it over.
    Ean Austral Guest
    Looking at it today its almost the same CCA as my starter battery on my D3. Maybe its the Red or Blue top they use instead of the yellow top. I guess it would get back to full charge pretty quick
    Cheers Ean
    Australia
    I was using a very tired (hot toasty in the D2 engine bay) 6yr old optima yellow top as my starter battery while my 130 build was happening.
    Never an issue to start including numerous purge cycles from less than full charge.
    That battery is now in service as a start battery in my sons car.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Ean Austral View Post
    I had a Yellow top as the starter in my D2. I got it to use as the second battery, by the starter battery died. I hooked it up and it worked flawlessly for 12 months, until the auto died. It is now doing service as the second Battery in my D1, and has done for two years. It went completely flat for some time when the isolator in the car failed, but has recovered and is again working well. I think it is a D35, but that's only from memory.
    As for the leads, well Yellow Tops are available with posts around either way. I had no trouble with fitment in my D2. I cannot comment with any authority whether the Yellow Top is ideal as a crank battery. However, my TD5 is a quick starter, and the Optima never had any difficulty, no matter how many times I started it a day, nor how many accessories I used in the meantime. I would have no hesitation using it again as a crank battery, but when the D2 is back with me I will probably get a Red Top or something else as a crank.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    May 2006
    Woolgoolga
    Quote Originally Posted by DiscoMick View Post
    They start my 4bd1 no worries at all!
    Red top is crank battery
    Yellow is a more a hybrid of crank/deep cycle.
    Both start my car fine
    Oct 2014
    Adelaide
    Would not recommend using a yellow top as bit low on CCA even though it has deep cycle/starting on it. There are better batteries around for cranking
    Rob
    Rob
    MY15 TDV6. Compomotives with KO2's, Traxide 160-DBMS, Llams, OE bar, custom rear storage slide, Rhino roof storage system, LSM TPMS, ICOM 440N, rear ladder and GOE compressor guard
    May 2006
    Woolgoolga
    Quote Originally Posted by RobA View Post
    Rob
    Why? They are 750cca!
    Dec 2011
    Adelaide
    142.79 MB
    I had a yellow top as a starter in my j**p wrangler and my perentie. Both diesels and no problems in either. Currently looking at a yellow top for my v6 petrol D3
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    DiscoMick Guest
    Yellowtops come in a range of sizes so it would be important to check the size required.
    404
