 Wizard
						Wizard
						For those who may have put a OA/OL rear wheel carrier on, what's the best way to get power to the extra indicator/brake/tail light?
TIA
Pete
Dizzie, 08 D3 TDV6 SE
 Wizard
						Wizard
						Many thanks sir. With a LRA tank in it, access to that spot is problematic. Would the use of the right hand cluster wiring be an issue?
Pete
I have the LRA tank. I picked up the power from the tail light and ran the wire out through the gap between the light and the rear bar. Simple.
Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
 Wizard
						Wizard
						Thanks. Does the LED lamp get "interfered with" by this connection? The reason for the question is that D3s aren't friendly towards trailer leds without load resistor packs.
Pete
 Wizard
						Wizard
						I used the right hand tail light cluster loom to pick up the necessary feeds.
Works perfectly - no interference with led lamps.
Thanks for the advice, gents.
Pete
