Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: EGR Valve Replacement on 2010 TDV8
    Rockingham, Perth
    Hi all,
    i have just had an engine fault diagnosed as a LHS EGR Valve needing replacement. Can someone please advise on what is the approximate time for a replacement ansd approximate costs. the Stealers just quoted me $2800
    thanks
    Feb 2009
    Quote Originally Posted by stusgonesailing View Post
    Hi all,
    thanks
    Geez that's brutal isn't it! Perhaps a $1000 remap including EGR deactivation would be money better spent?! (Disclaimer I have no idea if that would be an acceptable way to leave a faulty EGR valve!)
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Feb 2009
    PS have you tried pumping some cleaner through it?
    Rockingham, Perth
    Quote Originally Posted by Stuart02 View Post
    no i have not tried anything. just ran it straight into the dealer when all the warning lights went nuts
    Brisbane, Queensland
    I think LR wanted about $1500 for each part when I enquired last year. They had none in stock. So the remaining cost is labour.
    Whether to replace or disable or remap depends on what's wrong with the current EGR. It probably needs to be removed to work that out.
    Some or maybe all remaps don't fully disable the EGR, but reduce its operation so less exhaust is recycled.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Rockingham, Perth
    So i called BS on the dealer. Rang parts department and the EGR was only $660 (GST Inc) so that equates to 10 hours of labour to replace.
    Rang Ritters and the complete change was only $1400, They also recommended doing both for $2300
    Byford, WA
    TRS do a remap that disables the EGR's with no warning lights. I've been doing a lot of investigation n the last couple of days.
    I would inspect one, ensure it's in the fully closed position, immediately fit a pair of emulators to disable both fully. Emulators set cost $500 approx. That's what I did, before the EGRs failed.
    I bought this product about 1 year ago. I've been very happy with it. Some have experienced slow delivery and communication. I didn't.
    Land Rover EGR Emulator
    REMLR # 137
    Feb 2009
    The Superchip (aka Bluefin) remap on mine apparently disables the EGRs. I haven't tried to verify that.
    Byford, WA
    Hi rar110, where do the emulators go? Can I assume in the engine bay? By the way both MAP's cleaned both looked equally dirty. I'll see how I go tomorrow. Cheers Marty
