Results 1 to 3 of 3
Thread: MY 2012 Specifications or Brochure
    Rogera Guest
    Hi all, I've been a lurker for a while, I'm currently saving up to buy a D4, a 2012 model looks to be the limit of my budget. I have found the following on the Land Rover website (https://www.landrover.com.au/Images/...296-249120.pdf), and wondered if anyone could point me in the direction of something similar for the MY12?
    Thanks.
    EDIT: I found a link to the PDF disco_120_en_AU.pdf on way back machine, but it doesn't have the actual PDF archived.
    EDIT 2: Found 2013 docs.... Have found specs and brochure for 2013 (links below), can anyone tell me how much difference there would be between the 2012 and 2013 models, in particular between say the SE and HSE?
    https://web.archive.org/web/20131113...ications-2.pdf
    http://gencache.digitaldealer.com.au...8124119440.pdf
    Oct 2016
    Perth, AU
    http://australiancar.reviews/_pdfs/L...ure_201109.pdf
    I looked for the AU specs brochure when I was looking for a car, but also came up blank... In the end I wasn't as worried, because you only get the choice of whats on offer on the used market, and the vin decoder at TopiX helps understand what toys it was spec'd with
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Rogera Guest
    Quote Originally Posted by veebs View Post
    Thanks for that, it's a pity I'm not ready to buy yet as there is a nice HSE going at Barbagallo currently. Hopefully with the D5 deliveries will come more used D4's.
