 Originally Posted by
jboot51
				I have a boost pin on order.
In preparation for the install I have turned the existing pin to max fuel and trying to control the smoke with the star wheel.
The star wheel is 6 turns up from the bottom. Smoke screw is wound out so as to have zero influence.
This is in a 130 cab/chassis with a disco transfer case. 260k on the odometer.
So far the results are good with a little excess smoke down low on acceleration.
What sold me on the boost pin is it should get rid of the excess fuel down low.
Drivability at these settings is greatly improved. Fuel economy is an unknown at present.
 What EGTs are you getting?
1999 Disco TD5 ("Bluey")
1996 Disco 300 TDi ("Slo-Mo")
