Results 1 to 8 of 8
Thread: 2014 Range Rover Sport oil leak issue - any advice please
    Hi all
    My partner's 2014 Range Rover went in for a 60,000km service yesterday and upon picking up the car, she was given some bad news regarding an oil leak at the engine pump RH Turbo. Also the engine oil level sensor plus engine wiring loom requires replacing. See attached description from the dealer. Apparently about $5k in parts.
    Has anyone else ever come across this fault? Vehicle is the TDV8 and is just out of Landrover warranty, but it has an extended warranty. The company providing the extended warranty still needs to approach Landrover and seek approval for the work to be done under warranty.
    The issue is that we were going to be driving to the Hunter Valley for a holiday (from Brisbane) next Friday and we have been told not to drive the car until this is repaired. There are no visible signs of an oil leak from either externally, around the turbos, or around the back of the car from excess oil being burnt through the turbos and out the exhaust.
    Any advice here would be appreciated - ie can the vehicle still be driven long distance? I would have thought any drop in oil pressure would be picked up by other sensors.
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Mar 2007
    Warwick Qld
    Isn't the oil pump inside the engine? Replace wiring loom sounds a bit suss as well.
    Had an issue with the wife's Santa Fe the other day. Fuel filter needed changing but the mechanic said a $270 sensor needed to be replaced instead. (I was away at the time). Replaced switch and problem still there. Finally convinced him to replace filter, and problem went away! The sensor had been sending bad signals because the filter was blocked. Many so-called mechanics today simply follow the cues from the software without actually thinking of the underlying causes. Real easy, when the customer ends up paying for your laziness.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    NSW SW Slopes
    There could be minor leaks around the turbo and the harness entry to the sump for the oil level sensor that are of no significance but the leak at the oil pump which is in the front crankshaft cover could develop into a major problem. The front crank-shaft seal on the TDV6 can work its way out to cause major oil loss and the TDV8 looks to also have the same arrangement where the seal is just pressed into the housing, although I'm not aware this being a problem with the TDV8.
    Dec 2011
    Bundeena
    If they say don't drive it then don't.
    If something happens while you are driving it after they've told you not to, then you will have absolutely no hope of getting anything done under warranty.
    See if you can negotiate a loan car.
    Sean
    and......the vehicle is back at the dealers for the same oil leak around the oil level sensor......
    Anyone else having this issue?
    Vehicle is a 2014 SDV8 HSE with 84,000kms
    Andrew
    Dec 2009
    Ranelagh, Tasmania
    Quote Originally Posted by 86mud View Post
    I know the workshop manager at a JLR dealer and he mentioned these problems have been occurring when I talked to him about buying a L494 RRS. He also mentioned that the SCV8 has been known to do big ends but he did admit it was mainly customers from a certain ethnic background that had that problem.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    and the vehicle is back at the dealers for the same oil leak around the oil level sensor.
    Anyone else having this issue?....
    I have.
    If you are lucky the sensor O ring seal can be replaced without actually needing to remove the sensor ~half hour job. My dealer has done it.
    However, removing / replacing the sensor is a fair sized job due to all the other components which require removal first ~half day job.
    So try replacing the O ring first.
    Edit: just noticed we are not talking about the same engine. Not sure if above comments apply in your case.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    NSW SW Slopes
    The T/SDV8's oil level sensor is externally mounted whereas the T/SDV6's sensor is internal.
